Results 1 to 9 of 9
Thread: Slanty to flat front conversion.
    Senior Member Ksevn-T's Avatar
    Default Slanty to flat front conversion.
    Hey guys,
    When swapping front ends, new to old. What panels are required and is as simple as putting them all on or do you have to drill holes etc?
    Thanks,
    Alex
    lights, bumper, beaver, L+R guards, bonnet,
    i havnt done it but you should be able to drill new holes or the light brackets.. or you may need to get a rad support..
    Rian
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    To do it 100% you need all the removable panels from the bottom of the windscreen forwards and you also need to unpick the radiator support and weld on a flat front one.
    It is possible to not swap radiator supports, but you will need to muck around making brackets etc to mount the headlights.
    性交を愛する
    Here are two threads on it already.
    One and two.
    marvis.
    Im hoping its a drill and bolt on affair as i didnt get the rad support off the donor car, thought i didn't need it. Cheers for the reply's. If anyones had any more experience post up.
    Thanks,
    Alex
    性交を愛する
    If you want quads you will have to do radiator support, but otherwise you will be sweet.
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    cut everything out of there and make new brackets. then drill the bracket out. done.
    FTP.
    Veteran starni_boy's Avatar
    Clint
    Sutherland Shire
    You'll have to rewire the parkers too.
    AE71 front has blinkers and parkers on the one plug, KE flat front has separate plugs.
    Cheers for all the input. Discovered that i would have to rewire the parkers and blinkers.
    -Today got left and right quarters on and windscreen wiper panel. Have made my way into the next problem. Could not get the beaver panel on due to the aircon condenser and lines. Is it possible to have the aircon with old front? or is there no old front with aircon? Is it movable without re-gassing?
    Thanks,
    Alex
  1. ae71 slanty front to flat front conversion
    By benno93 in forum General Topics (No Technical Questions)
    Last Post: 28th July 2010, 01:53 AM
  2. anyone selling a ke70 flat front or slanty dosnt matter
    By drift-kidd in forum Cars or Parts Wanted
    Last Post: 23rd June 2010, 03:26 AM
  3. ae71 slanty front to flat front conversion
    By benno93 in forum KE70 / AE71 Owners Forums
    Last Post: 20th June 2009, 07:25 PM
  4. Slanty front conversion
    By corknose in forum Technical - Questions
    Last Post: 18th January 2009, 09:16 PM
  5. Slanty to flat conversion
    By ke70_sa in forum Technical - Questions
    Last Post: 11th June 2008, 03:27 PM
