Results 11 to 20 of 30
Thread: Will give this a try...help wanted for 86!
  1. #11
    Veteran Skylar's Avatar
    Ken
    Tom, the wiring on this car is pretty messy. I seen it, and you know it's bad if I think it's bad.
    I don't know if anyone can weld alu here but can I suggest riveting a steel bracket onto your rad support? Make stuff in steel which everyone can weld.
    Tell me how long you want the clutch line with what ends and I can make it with speedflow stuff from go-gear. My teflon line cost me a hundred bucks including fittings.
    Airbox should be real easy to make. Just get some aluminium sheet and put a 90 degree bend in it then cut it out where the pipe goes through. or mold one out of fibreglass.
    Did you have a high mount or low? I thought your exhaust fit fine? or are you going to quieten it down?
  2. #12
    Senior Member AE86 Spoontah's Avatar
    Brendon
    Ellenbrook
    I got ripped off hard coz i was new to 86's at the time. When i got it, it had no rims or tyres, no seat's, no steering wheel, no engine, no brake lines, no gear box crossmember, no fuel setup, shit house wiring, rust everywhere and shitloads more. But for whats in it you couldn't rebuild it for less than about $15g. I don't mean to sound like a tosser or you to think i'm big headed but i think it's one of the most heavily modified 86's in WA for something that isn't a dedicated track car.
  3. #13
    Brendon
    Ellenbrook
    I'm down with that. The more hands the better
  4. #14
    Brendon
    Ellenbrook
    All i need to do is move it so i can put the ecu behind the center garnish. It was messy but it worked
    Not really an option as some of the rivets would have to go into my fmic to secure th bracket firmly
    Justt needs to be standard 86 length with standard ends
    I have one semi made up but i don't like it very much.
    Low mount. Exhaust fits fine but is dead straight with no cat. It sits too low and only just clears under the diff
  5. #15
    Brendon
    Ellenbrook
    Good news everyone. haha
    Got the wiring all sorted out today after many cuts, swearing and some Beams. It look's alot neater now Skylar so you should come see it (and maybe wire in my horn and washer bottle haha)
  6. #16
    Ken
    Cool, good to see you working on it.
    When you say clutch line, you mean the rubber hose or metal line? cuz I was thinking the full line in teflon from master to slave.
    You have an F-series right? I don't think a rear anti-roll bar will bolt on because the pumpkin is now too big. You need a custom one or space out stock one whichever way it goes.
    I might be able to come by next weekend but this weekend is pajero motor back in + assemble SR.
  7. #17
    Brendon
    Ellenbrook
    Teflon from master to slave would be a hell of a lot easier. How much would it cost. I can give you the old steel and rubber one to match length.
    I have a whiteline one that fits but i'm missing the adjustable ends if that makes sense.
  8. #18
    Tim
    SOR
    I've got a passenger seat from a Levin sitiing here.
    You can have for free as long as you pick up before Monday.
  9. #19
    Ken
    This is what I was meant to ask last post. Which side is the slave on? I bought a metre and only used like 60cm for my car(slave on driver's side). It was ~100 for 2x m10x1 or inverted flare (can't remember) to -4, 2x -4 90 and a metre of -4 teflon. I still have one of each sitting around because I didn't have enough room to run it and ended up with a m10x1 banjo straight and -4 straight.
    So it's just a matter of ordering the chassis side mounts and maybe links for the ARB? or you wanna try make something?
  10. #20
    Brendon
    Ellenbrook
    Shit yeah.PM me your addy and i'll come round sunday arvo
  1. Replies: 1
    Last Post: 23rd February 2010, 06:44 AM
  2. 86 parklights wanted
    By lil_cons in forum Cars or Parts Wanted
    Last Post: 8th January 2010, 12:44 PM
  3. 86 bonnet wanted
    Last Post: 27th October 2009, 08:18 PM
  4. 86 Parts wanted
    By RolandGTV85 in forum Cars or Parts Wanted
    Last Post: 22nd March 2009, 04:54 AM
  5. oz 86 wanted
    By SEXY 16 in forum Cars or Parts Wanted
    Last Post: 31st July 2007, 11:50 PM
