Results 1 to 10 of 13
Thread: MASSIVE HEADACHE ! ae86 front brake issue
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    Default MASSIVE HEADACHE ! ae86 front brake issue
    Ok guys so heres the problem
    i got a jdm 86, havnt changed brake system since it came from jland, first people to have their hands on this car was holford motors,
    So i got new pads and discs from GSR rallysport (sponsor on this forum), realised that my origional discs on the front werent vented, tried pads and discs on didnt fit into my caliper, so i had guessed i had ae85 brake setup for some odd reason or some sort ?
    Anyway i ordered jdm 86 calipers from japan, tried them on my car, when trying to bolt up i realized the bolt holes are about an inch off ? so i have no idea ive never looked into anything until now and i cant find any info between JDM and ADM ae86 or even ae85 brake setup.
    Regards,
    David.
    Dave
    Western Suburbs
    also heres another quick Q do adm ae86 calipers have a diameter to bolt into caliper brackets to jdm ae86 calipers?
    Veteran slydar's Avatar
    Dimitri
    a jdm caliper will bolt up to an "adm" caliper bracket. sounds like your car came with TE71/2 struts or something.
    78's
    Dave
    Western Suburbs
    really ? i first got the car with standard springs and struts, changed out into revolver built coilovers and put this brake system on to them
    later on i made up my own coilover kit and put these brakes on and thats what im using currently, surely one of the 3 pairs have been ae86 struts ? they supposeably were and these struts came off a friends car, i just dont understand why jdm ae86 calipers would have a different lengh in diameter for it to bolt up!
    Senior Member gslrallysport's Avatar
    Greg
    I've just checked the part numbers we supplied, and both front and rear rotors and pads are were definitely JDM AE86, so if you've sourced JDM calipers, and it still doesn't bolt up, then I'm leaning towards it being a strut issue like slydar said.
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Dave
    Western Suburbs
    3 pairs of struts all being non ae86 seems fairly slim to me as i also seen the most recent struts being off an ae86 that was bought straight off an old lady
    then i got the struts straight after cause my mate changed to s13 front end?
    Dimitri
    ok, was just suggesting because TE7X struts are pretty close to 86, but the caliper bolt spacing is out by about what youre suggesting.
    ae86 strut/brake set ups are exactly the same adm to jdm, except for the caliper and disc. people have been bolting jdm calipers and discs onto adm struts/caliper brackets/hubs for years.
    so the brakes are the ones that came on the car? whatever they are, it seems like theyre some type of unique jdm brake package. i can tell you, without modification, a TE caliper bracket wont go on an 86 strut, the bolt partern is different.
    maybe you should ask on some american forum. see if sr5 brakes bolt up to gt struts.
    78's
    Greg
    Are you sure the calipers you've got are JDM AE86? Have you tried fitting the pads into the caliper off the car?
    Dave
    Western Suburbs
    i ordered the calipers straight from japan and they are for an ae86, got a Japanese person to look over information before i purchased, and yes the ive tried fitting the pads into the caliper before putting them on the car.
    Greg
    I've got DB322 on the invoice supplied, just double check that what was in the box actually was DB322:
    And if those pads don't fit, then you ain't got JDM AE86 calipers.
    Also, the calipers have a number on them, I don't know what it's supposed to be (not being familiar enough with them), but somebody here will.
  1. Brake pad clearance issue on front AE86 ADM rotors/calipers
    By Alexrex7 in forum Technical - Questions
    Last Post: 18th October 2012, 09:56 AM
  2. (ex-)Daily headache
    By squish_m8 in forum KE70 / AE71 Owners Forums
    Last Post: 10th November 2010, 08:29 AM
  3. ae86 front brake caliper
    By spoon in forum Cars or Parts Wanted
    Last Post: 18th May 2009, 05:17 PM
  4. brake issue....wont bleed properly!
    By Simon-KE70 in forum Technical - Questions
    Last Post: 13th February 2009, 02:38 PM
