pics of shell?
All items located sunshine coast QLD, pick up or you organise freight for larger items, will post small shit.
1 KE70 rolling shell, 4age conversion gear, WELD IN half cage, mod plated, flat front, no interior, has dash tho, spirit boot, all glass/panels/lights, s diff and ke struts. Needs work $800 or make a fucking offer
2 Blacktop 20v, loom, ecu, water lines and near new ae82 radiator. Custom NPC 5 puck clutch, trumpets trd extractors $old
3 T series diff, 4.1 locked has tailshaft $400
4 T50 gearbox, 4th gear sycro is dicky otherwise good condition $old
4 86 coilovers, 10kg swift springs, koni yellows, hubs brakes etc. $700
5 koni red rear shocks with cut falcon springs $150
6 15x8 -4 superlights have usable goodyear eagle f1 tyres 2 have gutter rash 2 are perfect $700
the 2 good ones
7 W57 conversion for 4age, t50 bell, AZcustoms adaptor and spigot spacer, shifter $1000
8 Oil cooler + sandwich plate, worked well on the 20v $old
that just about does the bigger parts, will add moar when i pull it off.
pics of shell?
Im guessing its running the standard ecu?
Is the dizzy still mounted on the rear of the engine with a boxed section in the firewall, or on the front?
Cheers,
Andrew
I'll grab the oil cooler biggus, Pm'ed.
Hey mate, I'm interested in the motor and box. How many kms on engine and do u no how much to get sincro fixed
