Results 1 to 8 of 8
Thread: W5X box bolt-in setup
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Default W5X box bolt-in setup
    Doing a W57 conversion for somebody and I just wanted to double check the plans with people. This is just going off my head (can't get to old forum to check these things again) from what I read before. This is all to go into a turbo 4A sprinter.
    - W57 Box
    - W-A Bellhousing
    - AE71 Auto crossmember
    - RA40 Manual front half of tailshaft
    - SA63 Shifter location (to suit standard shifter hole)
    - Custom clutch to suit W spline and appropriate 4A flywheel (in this case 200mm)
    And depending on the bellhousing use a JDM AE86 slave.
    Does that sound correct for a bolt in job?
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    ae71 x member doesn't fit exactly... I ended up chopping it and welding some plates..
    BENT MECHANIX - Garage 20:
    Veteran biggo's Avatar
    Nick
    Noosa
    I used some landcruiser clutch. $56 from repco. 200mm
    RA60/RA65 shifter locations definately fit. I think the SA63 is slightly more forward?
    Niz
    South~Slide Briz
    yeah not sure on the shifter locations, my w55 was supposedly from a corona and it lined up perfect.
    Lawrence
    Wollongong
    Quote Originally Posted by NIZLAH View Post
    Interesting, I have sold 2 of these for this purpose, although I never got feedback from the buyer.
    I was under the impression that it was around the other way, the box I will be getting is from an RA60 so hopefully it'll work just as is.
    Thanks for people's help so far
    Reeece
    Casula
    i used a celica slave cylinder bigger bore as the t18/ae86 couldnt push my clutch in.. you can make a xmember by following these instructions
    http://www.toymods.net/forums/showth...t=w58+sprinter
    Nick
    Noosa
    or ra60 and redrill the holes
    ketos are different but you dont need to know that
    Dave
    Nsw
    Livo
    i made a 10mm adapter plate for the rear of the t50 bell housing (so slave is still in same place as well as fork) countered bolts to the box (had to retap box to new thread) then some mods to the bellhousing and it bolts to the plate, sit perfect in the shifter position.
    clutch wise i had to go a tarago one so it fit the w box shaft and still fit in the gze gear i had previously, only got the clutch plate its self (round $200) and used the exeedy pressure plate i already had best i could get was a ceramic 4 puck... will c how it holds... anyone know a better clutch plate to use?
  1. Replies: 7
    Last Post: 8th April 2012, 12:37 PM
  2. Rebuild or buy another w5x box?
    By rymax86 in forum Perth & WA Events and Discussion
    Last Post: 4th September 2011, 08:10 PM
  3. Bolt In Sigma LCA Setup
    By sonsta in forum Car Parts For Sale
    Last Post: 6th July 2009, 02:57 PM
  4. Bolt on 4AGZE charger setup with ECU and loom
    By foxtail in forum Car Parts For Sale
    Last Post: 30th July 2008, 07:36 PM
  5. mags, bolt on spacers, s13 full front setup
    By fat exa in forum Car Parts For Sale
    Last Post: 8th February 2008, 04:38 PM
