To keep VVT, you need cams from Toda. They have an Australian distributor. But if you are using different cams, I assume you have a programable computer? Maybe the stock computer can run mild cams. And if you have a programable computer, you realise the VVT will be another pain in the brain to work out.
Kelford in NZ also do 20v cams.
