Page 1 of 12 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 118
Thread: Lower Control Arm- Measurments & Compatibility
    Dan
    Vic
    Western Subs
    Post Lower Control Arm- Measurments & Compatibility
    Ok guys
    im still confused with a few things
    i found a list of LCAs and what sizes etc...
    Model - Length - CT Dia
    RA40 - 300mm - 12mm
    TA22 - 300mm - 12mm
    AE86 - 300mm - 12mm
    KE7x - 300mm - 12mm
    XT130 - 310mm - 12mm (RT132 too?)
    MX73 - 304mm -12mm
    MX62 - 365mm - 12mm
    GE Sigma - 330mm - 12mm
    S13 - 350mm - 14mm
    now it seems everyone goes with the XT130s what i want to know is if i do the same what exactly do i need to do the job, what parts do i require i know i need the XT130s but what else and has anyone one done a write up fo this?
    thanks
    Veteran slydar's Avatar
    Dimitri
    nothing else.
    the xt corona has lock stop on the lca. you need to cut these off. thats it. your stock tie rods and rack ends will have enough adjustment in them. if you have power steering as as well though, you might want some longer tie rods or rack ends.
    you can grab the tie rods off the corona as well. theyre a 2 piece turnbuckle design, and have a greater range of adjustment, and are on car adjustable too.
    if your tie rods you have on your car are new say, but your stock rack ends are fucked, just get ra60 rack ends. theyre a touch longer.
    either set up will be long enough.
    also xt/rt 13X are all the same.
    Dan
    Vic
    Western Subs
    would it be better to use mx62s?
    Dimitri
    no. i would only use mx62 arms if you want full "oni kamu" style. its really too much to work properly. youre talking in the region of a minimum 6 degrees negative camber. maybe 5 ish with strut tops wound full positive.
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    if i wanted -3 camber and had strut tops + RA60 struts, what arms should i be using? i was guessing sigma but am unsure
    c
    I thought ra40 and xt130 lca were the same length
    c
    Quote Originally Posted by riojin View Post
    Yeah sigmas mate
    Veteran driftke70's Avatar
    Ryan
    Buderim
    mx62 would only really be good to cut up into adjustable ones as you have more meat to play with and would likely be bit thicker and stronger than other yotas of the same style lca
    wheelfriends.wordpress.com
    Im using XT130 LCA's, KE30 Tie Rod Tubes, and RA40 Tie Rod ends on a KE70 rack. Can be adjusted to be even shorter or heaps longer then stock Tie rods.
    <img src=http://img114.imageshack.us/img114/3193/p1020339jk4.jpg border=0 alt= />
    Anyone get the License plate of that B& Hammer?
    性交を愛する
    Quote Originally Posted by driftke70 View Post
    Agreed. I have them on my RA65 and it's heaps of track. I run 14x7 0 offset with about 4-5deg neg camber so they sit under the guards.. Will be going s13.
  1. Lower control arm identification
    By ke_70_blue in forum Technical - Questions
    Last Post: 13th November 2012, 06:41 PM
  2. Replies: 22
    Last Post: 25th August 2011, 03:15 PM
  3. WTD: lower control arm!
    By sprintrphile in forum Cars or Parts Wanted
    Last Post: 18th August 2009, 09:50 PM
  4. lower control arm bolt, getin it back in
    By duurs in forum Technical - Questions
    Last Post: 14th November 2007, 09:51 PM
  5. lower control arm problems.
    By Trucka 115 in forum Technical - Questions
    Last Post: 25th September 2007, 12:43 PM
