Page 12 of 12 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12
Results 111 to 118 of 118
Thread: Lower Control Arm- Measurments & Compatibility
  1. #111
    Adan
    Oxley Park
    techno toy tuning make a kit.
    but my gut tells me that if you need to ask for a tutorial on how to do it, you probably shouldnt do it. LCA's are kind of important on a car...
  • #112
    Senior Member Hachi_Tom's Avatar
    Mar 2010
    Tom
    Ashmore
    i know how to do it i guess, just wondering on the would one rose joint be good enough what strengthening needs to be done... i can do the work.
  • #113
    Adan
    Oxley Park
    hmm well in that case, I would look on the T3 website and pretty much copy their design if you dont want to buy the kit.
    I was looking at doing the same thing, but concluded that for the amount of effort and time it will take, it will end up cheaper to buy the T3 kit.
    Maybe even look at making a whole new arm and replacing the ball joint with another rose joint? Anyone have opinions on this?
  • #114
    Gunner
    Thought I would add that MX32 LCA's come in at 335mm.
  • #115
    Gunner
    So what steering arm combo would be needed to pull 45mm positive adjustment? ANyone got an idea?
  • #116
    Veteran timbo's Avatar
    Tim?
    Wild West
    Quote Originally Posted by greenmac80 View Post
    ok so when people here say. 'bolted these in' i'm assuming they all got the steering arm machined as well?
    so its most definately not a bolt in job.
    old thread dig up but help a brother out.
    the quote is reffering to sigma lca's. what exactly needs machining? slightly confused after reading th entire thread at 10.30pm after multiple beers...
  • #117
    Tim?
    Wild West
    nvm, bit of googling and now i see the problem.
  • #118
    Junior Member AE25's Avatar
    Mark
    Auckland
    south
    New Zealand
    thought i'd add.. people asking about mx83/gx8#/jzx8# lca's .. they have a larger bolt through the pivot bush. (other end to the ball joint).
    and could the OP please update the first post so the list is corrected?!!
    re ball joints.
    A6 celica/carina *4cyl* have same ball joint thread and taper as ke3/e7/tt132/ae86.
    ma6/ga6 celica-supra 6cyl have a larger taper but with same 14mm thread. mx8#/jzx8# etc have a larger taper ball joint than the ma61.
    compared these moons ago.
    -Mark
    E2 & E7 fanatic
    ke20 ke25 ke26 kp60 kp61 ke70 ke74 ae82 st185
  • Page 12 of 12 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12
    1. Lower control arm identification
      By ke_70_blue in forum Technical - Questions
      Last Post: 13th November 2012, 06:41 PM
    2. Replies: 22
      Last Post: 25th August 2011, 03:15 PM
    3. WTD: lower control arm!
      By sprintrphile in forum Cars or Parts Wanted
      Last Post: 18th August 2009, 09:50 PM
    4. lower control arm bolt, getin it back in
      By duurs in forum Technical - Questions
      Last Post: 14th November 2007, 09:51 PM
    5. lower control arm problems.
      By Trucka 115 in forum Technical - Questions
      Last Post: 25th September 2007, 12:43 PM
