Page 3 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 21 to 30 of 118
Thread: Lower Control Arm- Measurments & Compatibility
  1. #21
    xt130 lca are 12.8mm x 300mm i bought some today lol
  • #22
    Dan
    Vic
    Western Subs
    i just got a pair of RA40 Lower control arms and i just want to make sure of something,
    i dont need to get anything else to bolt these on besides new bearings true/false?
    . h i t o r i k o .
  • #23
    Veteran anastasios's Avatar
    Taz
    Earlwood
    yea im using 55 lcas in my 70 with no problems gives me about 2 deg of camber
  • #24
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    how do t3 items go? how much they give at full lenght and how much they go at shortest lenght?
  • #25
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Quote Originally Posted by hitoriko View Post
    I'd like this clarified also....
    Are new rack ends or tie rods needed at all? if so what is the best solution/option?
    BENT MECHANIX - Garage 20:
  • #26
    Jonathan
    If you use 10mm longer control arms (such as RA40), you then need to adjust your tie-rods 10mm longer. I think there is just enough thread on the rack end, but don't take my word for it, check this. A safer option is to change to RA40 tie-rods, with the seperate ball joint on the end. You will then have more adjustment, and enough thread to make it safe.
    Or, if you use a steering rack spacer for extra lock (with requires shorter tie-rods) the effect may cancel out and you can use standard tie-rods and rack ends.
  • #27
    Niz
    South~Slide Briz
    sweet, that's all I needed to know.. Cheers Jonny
  • #28
    Moderator Frak's Avatar
    Jamie
    Measured Cusco fabricated LCA, 305mm
    Hachiroku since 1994
  • #29
    Keisuke
    Auckland
    North shore City
    New Zealand
    Hi guys,
    I have powersteering in my 86,
    Planning on using KE30 LCA`s as they are same as Xt130 & TT132.
    If I get Longer Tierods is that all I will need? I wont need both longer tie rods and rack ends?
    Cheers Keisuke
  • #30
    Senior Member Ksevn-T's Avatar
    If i put sigma arms on my xt130 struts and cranked my camber tops all the way out to battle all that camber. How much camber would i be left with? or just a shit load of track?
    数独のガレージ "Sudoku Garage" <3<3<3
  • Page 3 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
    1. Lower control arm identification
      By ke_70_blue in forum Technical - Questions
      Last Post: 13th November 2012, 06:41 PM
    2. Replies: 22
      Last Post: 25th August 2011, 03:15 PM
    3. WTD: lower control arm!
      By sprintrphile in forum Cars or Parts Wanted
      Last Post: 18th August 2009, 09:50 PM
    4. lower control arm bolt, getin it back in
      By duurs in forum Technical - Questions
      Last Post: 14th November 2007, 09:51 PM
    5. lower control arm problems.
      By Trucka 115 in forum Technical - Questions
      Last Post: 25th September 2007, 12:43 PM
