Page 8 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 71 to 80 of 118
Thread: Lower Control Arm- Measurments & Compatibility
  1. #71
    Sep 2009
    i'm sure most of this has been covered through the thread but not in an entirely direct manner.
    i will be using Power Steering arms, lock spacer and XT130 LCA's on an AE86 Strut.
    heres my questions, inb4 flaming for noobness or not reading thread properly rabble rabble.
    1. i know i need to cut off the lock stops but when i rebush/joint the LCA do i use Xt130 ones or AE86 ones?
    2. will it be necessary to run different rack ends or tie rod tubes/ends?
    3. if so do i just want the tie rod ends or tie rod ends + tubes?
    4. will any of this change when i coil over the strut with Camber Tops and RCA's?
  2. #72
    Moderator Sam-Q's Avatar
    Endeavour Hills
    1: the bushes should be the same but to be sure order xt130 ones
    2: no
    3: -
    4: no
    easy eh?
  3. #73
    Sep 2009
    went to u pull it today and got my self some XT130 LCA's, was too lazy to unbolt everything so got the steering arms and tie rod ends at the same time.
    best $36 i ever spent.
  4. #74
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    someone should make a guide on fitting them with all different combinations lol and refurbishing the LCA's
  5. #75
    Jul 2009
    Josh
    Ballarat
    Trial and error works! lol
    refurbishing them is as easy a getting the grinder out and a black pressure pac!!
    Chop off lock stoppers,clean and paint! of course you could go all out and powder coat em?
    Bushes and ball joints need to be pressed in at a shop that can do so..
    Josh
    43ger
    Performance
    SINCE 2008
  6. #76
    Jun 2009
    Myka
    Byron Bay
    if anyone knows the length of mx83 lcas that would be awesome!!
  7. #77
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    +1 on mx83 arms... thinking i want 10-20mm per side more track
    MY JZX83 (clicky)
  8. #78
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    GJ sigma LCA's and ae86 LCA's
    edit*
    Q: anybody know the length of GJ sigma LCA's? or are they the same as GE sigma LCA's?
    A: measured the GJ sigma LCA's and they're about 340mm-350mm. To fit these i have had to get the balljoints machined to fit the powersteering arms and have had to get ae86 bushes(60mm) replacing the 65/66mm GJ sigma bushes
    hmmm, running these would probly give about 5 degree neg camber with no cambertops... and probly 3 degree negative!? as the minimum with cambertops.
    will post what i end up with.
  9. #79
    Filip
    Jozzaville
    anybody ran GJ sigma arms before? pro's? cons? opinions?
    also, anybody know, if i use johnny's extra lock tie rod ends with stock ae86 rack ends, will there be enough adjustment to get them to reach or will i have to upgrade to something? not too sure about rack ends so somebody let me know.
    Fil.
  10. #80
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    i sense geometry failure with sigma arms + some.
    don't be cheap and use camber tops (+xt130 arms) is a winner.
  1. Lower control arm identification
    By ke_70_blue in forum Technical - Questions
    Last Post: 13th November 2012, 06:41 PM
  2. Replies: 22
    Last Post: 25th August 2011, 03:15 PM
  3. WTD: lower control arm!
    By sprintrphile in forum Cars or Parts Wanted
    Last Post: 18th August 2009, 09:50 PM
  4. lower control arm bolt, getin it back in
    By duurs in forum Technical - Questions
    Last Post: 14th November 2007, 09:51 PM
  5. lower control arm problems.
    By Trucka 115 in forum Technical - Questions
    Last Post: 25th September 2007, 12:43 PM
