Page 9 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 81 to 90 of 118
Thread: Lower Control Arm- Measurments & Compatibility
  1. #81
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    Quote Originally Posted by keiichi View Post
    i sense geometry failure with sigma arms + some.
    don't be cheap and use camber tops (+xt130 arms) is a winner.
    yer i will be running cambertops, just wanted to know what the sigmas would give without cambertops
  • #82
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    Quote Originally Posted by Hen may possibly be a nut View Post
    MX62 are way too long for normal use, and also their balljoint is alot bigger than AE86 so donøt suit the steering arm. Use them only for S13 conversion.
    what if i were to use the mx62 knuckle, brakes, strut etc aswell? since the spindle may actually be at a different angle.
    i am buying an rt142 and for a brake/track/camber upgrade im considering using mx83 or mx62 front end stuff (converted to coil-overs). i have a feeling that perhaps an mx62 strut/spindle on say a 300mm long LCA will lead to positive camber.
    what do you think?
  • #83
    Zac
    Sunnybanku
    Quote Originally Posted by dave2221 View Post
    mx62 cressida LCA:
    and the end result: (keep in mind these rims are like +20 offset)
    damn that actually looks perfect... have you got a RCA in there? how much camber is that? camber tops?
    what strut/spindle/hub/brake, steering knuckle, tierod, castor arm etc did you use?
    any more pics from underneath?
  • #84
    Zac
    Sunnybanku
    did this thread go and die or something?
  • #85
    ill revive the thread!
    has anyone fitted mx83 control arms? im running the GJ sigma arms at the moment and they bit too long (longer than the GE ones, being 340mm i believe). someone selling mx83 arms and they measure at 330mm. Wasnt sure if they balljoint suits ae86 steering arms along with castor rod holes and swaybar pins.
  • #86
    Jun 2009
    Ollie
    Wanted to ask whether longer caster/ tension rods are needed when fitting xt130 lca's, or any longer lca's for that matter?? Or is there enough play in the stock rods to fit in the existing holes?
  • #87
    Veteran stx-16's Avatar
    Tweed Heads
    yeah they fit its just a c**t to get in but it will fit i have sigma arms in my ke70 and i dident even have to adjust it at all just needed a little beating
    you play halo?
    add me GT: samnbhnc
  • #88
    Apr 2010
    mad thread. i got 86 struts, ps arms,rt132 lca. bought lcas not knowing if it was right but feel a lot better now. the xt130 and rt132 were the same bodies so i took a punt. ive never heard anyone use a different model name except xt130 so thought it had to be them and them only. theres no xt130s in the wreckers but heaps of the other model. from a streeters pont of view, fuck sigma looks excessive. car looks mad yes but i dont think -5 camber is gunna benefit the car at all. tyre wear would be rediculous. probably mad on a race car though. is anyone out there running sigma on the street?
  • #89
    Tweed Heads
    yes me
    i got a mates dad (boilermaker) to cut 18mm out of my camber tops so i could wind the camber out more now i have -1.5 degs
    you play halo?
    add me GT: samnbhnc
  • #90
    Apr 2010
    your car in the members rides section?
  • Page 9 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
    1. Lower control arm identification
      By ke_70_blue in forum Technical - Questions
      Last Post: 13th November 2012, 06:41 PM
    2. Replies: 22
      Last Post: 25th August 2011, 03:15 PM
    3. WTD: lower control arm!
      By sprintrphile in forum Cars or Parts Wanted
      Last Post: 18th August 2009, 09:50 PM
    4. lower control arm bolt, getin it back in
      By duurs in forum Technical - Questions
      Last Post: 14th November 2007, 09:51 PM
    5. lower control arm problems.
      By Trucka 115 in forum Technical - Questions
      Last Post: 25th September 2007, 12:43 PM
