Page 4 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 31 to 40 of 118
Thread: Lower Control Arm- Measurments & Compatibility
  1. #31
    Jonathan
    Get out your ruler.
    Then get out your sin, cos and tan.
    Then flare the gaurds.
  2. #32
    lewis
    colonel light gardens
    hey i just put sigma lcas in my ra40 celica
    i got 3 degreas of camber
    and yes r40 and carona lcas are the same
    im not sure about other celicas
  3. #33
    Senior Member dave2221's Avatar
    mx62 cressida LCA:
    and the end result: (keep in mind these rims are like +20 offset)
  4. #34
    Aaron
    have you got your tyre on the wrong side of the car??
    just looks like tread pattern is the wrong way round
    actually it is on the wrong side of the car.
  5. #35
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    anyone got pics of lca? i cant seem to get any pics of any lca, i need some pics to do some comparisons
  6. #36
    yup
    but since the engine isnt connected i didnt see it as a big problem
  7. #37
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    i have got a set of ke30 adjustable chilling and they are any length u want them to be i will get pics up asap for a reference
    the dyno pull to 300rwkw
  8. #38
    Senior Member OMG866's Avatar
    Nick
    Miranda
    are they still fs mat
    100 bucks cash
  9. #39
    Veteran blair's Avatar
    Blair
    SEQ
    adjustable is the way ahead.
  10. #40
    Junior Member AE25's Avatar
    Mark
    Auckland
    south
    New Zealand
    ke30 and tt132 (xt130) are identical from the ones i've pulled from cars. measured my ke70 lca at 290mm and ke30/tt132 at 300mm. whichever way you measure theres about 10mm longer there. bolted up with a wee tweak to suspension angles.
    my front suspension consists of ma45 (jdm) strut with std 10" solid disks, ae86 p/s arms, tt132 lca, ae92 shock spaced down, makita springs. i gained -1deg camber each side and also +1deg on the caster when wound all way forward which is now 3.5deg. once i get rca's in there it'll probly bring it back to vertical so then camber plates should hopefully get my -2deg.
    -Mark
    E2 & E7 fanatic
    ke20 ke25 ke26 kp60 kp61 ke70 ke74 ae82 st185
  1. Lower control arm identification
    By ke_70_blue in forum Technical - Questions
    Last Post: 13th November 2012, 06:41 PM
  2. Replies: 22
    Last Post: 25th August 2011, 03:15 PM
  3. WTD: lower control arm!
    By sprintrphile in forum Cars or Parts Wanted
    Last Post: 18th August 2009, 09:50 PM
  4. lower control arm bolt, getin it back in
    By duurs in forum Technical - Questions
    Last Post: 14th November 2007, 09:51 PM
  5. lower control arm problems.
    By Trucka 115 in forum Technical - Questions
    Last Post: 25th September 2007, 12:43 PM
