Page 11 of 12 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 101 to 110 of 118
Thread: Lower Control Arm- Measurments & Compatibility
  1. #101
    May 2010
    Derryl
    CA
    Napa Valley
    United States
    inners and outters? or RUNNIT with a sleeve like numbers 4 and 5?
  2. #102
    May 2010
    Derryl
    CA
    Napa Valley
    United States
    disregard that. i got it. thanks!
  3. #103
    Will
    Anyone got a known measurement for an XT14X corona? i tried to measure compared to an XT130 but i only had a ziptie to measure with. Im thinking the MX62 arms will go well on a corona somehow...
  4. #104
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    st141/rt142 are the same length as kesev ae71 sprinter... like, 300mm i think. mx62 will be ridiculously long but they are how-ever a good thing to use when doing s13 front end. i used silvia recently and they are shorter so a bit more conservative but more drilling to make it fit and less castor due to mounting points.
  5. #105
    Luc
    Seaford
    is that a big crack running down your caliper?
    but man those weld on kits look the shiz!
  6. #106
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I dont see any crack, a casting mark yes
  7. #107
    Jul 2009
    shaun
    nsw
    port macquarie
    ive read the hole artical but i have stock suspension just upgraded springs and the car is lowered, from what i can understand i can put xt130 lca in my ae86 and use all my standard parts that are in my ae86 (i have no power steering). i dont have camber adjusters either, and what i want to know is what camber will the xt130 lcas give my car if i fit them only???
  8. #108
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    -1 to -1.5 degrees
  9. #109
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Yeah, dont bother unless you are going to a full MX83 front end. I have a full MX83 front end on my Supra, and its quite nice, but the balljoint is unique to the MX83 and so you need to use the matching steering arms, and then the matching struts as they are odd spacing too... etc.
  10. #110
    Senior Member Hachi_Tom's Avatar
    Mar 2010
    Tom
    Ashmore
    So if i wanted to cut my LCAs and make them longer, about 10mm would give me an extra degree or so? and also, also would like adjustable LCA's so if any1 has a build/howto thread on what you need to do that would be awesome
    sorry if its been in this thread before, i just quickly read over it.
  1. Lower control arm identification
    By ke_70_blue in forum Technical - Questions
    Last Post: 13th November 2012, 06:41 PM
  2. Replies: 22
    Last Post: 25th August 2011, 03:15 PM
  3. WTD: lower control arm!
    By sprintrphile in forum Cars or Parts Wanted
    Last Post: 18th August 2009, 09:50 PM
  4. lower control arm bolt, getin it back in
    By duurs in forum Technical - Questions
    Last Post: 14th November 2007, 09:51 PM
  5. lower control arm problems.
    By Trucka 115 in forum Technical - Questions
    Last Post: 25th September 2007, 12:43 PM
