Results 1 to 3 of 3
Thread: pistons heights. Something ain't right..
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Default pistons heights. Something ain't right..
    Hi guys...
    I just bought a set of hi comp pitons for my bigport build.
    There are exactly the same as small port pistons but with the right sized 18mm pin bore..
    Being the curious person I am... And having a disasembeled small port in my garage is thought I'd compare the too to see just how similiar they really are..
    Weeeeellll...
    Visually there identical untill I noticed that the pin heights are different...
    Small port pin height measured form top of piston to center of gudgeon
    = 30.25mm
    The new pistons I bought only = 27.6mm
    Fitting these piston would lower my compression ratio a whole 2.3 points.
    From a ( If they were right ) 10.32 down to only 8.06
    Any ideas.???? I'm unaware of any rod or block deck hieght differences between models.. Why is this so.??
    These look just like genuine 4a pistons... With the ART stamp on the side and all..
    Jason
    Nundah
    Ok guys problem solved.....
    Turns out piston are for a HKS 5a stroker.....
    took friggin ages to find that out though...
    And now I'm back where I started...
    Moderator Sam-Q's Avatar
    Endeavour Hills
    how odd I wouldnt of thought anyone would sell parts to suit that rare HKS kit
  • Similar Threads
    1. Setting up coilover heights?
      By Stej in forum Technical - Questions
      Last Post: 7th August 2009, 02:38 PM
    2. Hachis ain?t s**t but hos and tricks
      By marvis in forum Offtopic Discussions
      Last Post: 18th February 2009, 08:00 PM
    3. Replies: 6
      Last Post: 15th July 2008, 08:28 PM
    4. Coilover Heights??
      By -=GOODY=- in forum Technical - Questions
      Last Post: 9th November 2007, 01:30 PM
