Results 1 to 10 of 11
Thread: Engine damper - backyard style
    Default Engine damper - backyard style
    hey guys just lookin at some opinions on what ive done, had some stiff as shit gas struts sitting in my shed, got bored last nite and decided to fit one into the engine bay from strut tower to the block ( strut compressed of course) now any negatives on doing this? will i have the same effect as an off the shed strut to engine brace? have i done something good
    Senior Member 45aken's Avatar
    Marko
    I can't see any negatives, but i dont know how effective it will be being so low on the motor. think levers
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    thats kool, i wanna try it
  • #4
    45AKEN you might be right on that, didnt think about it. might see how high i can put it, might have to end up moving it cause the way my RWD water setup is i can mount a SC on it if i decide to
  • #5
    Senior Member Simon-KE70's Avatar
    Simon
    i have something that would be perfect.
    its a gas strut from a volvo truck seat. its short stiff and compact with eyelet bearings on both ends.
    i suggest going to a truck wreaker and grabbing a 2nd handy
  • #6
    Marko
    somewhere like the lift hooks on the motor would be great.
    also the other side may be more effective as the motor will tend to twist that way with the throttle.
    for mounting you could bolt a bit of flat bar to one of the strut top bolts.
  • #7
    i more so put it on that side cause it kinda pushes the motor away from the clutch master where my trumpet hits. just kinda gives it that little extra. i have another one so i was thinking of puting it on the other side. car is gonna be used for hill climbs and a bit of drift so the mounts will be copping a fair flogging
  • #8
    Marko
    cool man,
    well either way if in its normal state the strut is compressed then it'll force against movement both ways.
    if you got some flat bar and bent it like this
    __
    .. \___
    you could bolt it to a bolt on the left strut top and it would give you a nice sturdy mounting point for the strut at a good height too.
  • #9
    i used to have one on my dc5r there good mods if correctly mounted, made.
  • #10
    Junior Member keto70's Avatar
    koskenkorva
    Töölö
    Finland
    nissan primera p10 boot struts are short .. thinking to use them in my ke70 .
  • Page 1 of 2 1 2 LastLast
    1. Imagine this being your backyard!!!!
      By haydenz in forum Offtopic Discussions
      Last Post: 1st September 2009, 12:52 PM
    2. backyard sickness
      By daily_driven_death_sled in forum Offtopic Discussions
      Last Post: 9th April 2009, 11:41 PM
    3. Engine Torque Damper
      By RolandGTV85 in forum Technical - Questions
      Last Post: 19th March 2009, 03:19 PM
    4. Engine Torque Damper
      By h1_roll4 in forum Cars or Parts Wanted
      Last Post: 16th August 2008, 09:16 PM
