If it's really dark, it can be oil - meaning at some point in its life, the one-way valve was fucked in combination with an engine that has positive crankcase pressure resulting in your brake booster turning into a catch can. I've seen if before. Brake fluid is normally alot lighter than this.
The viscosity of the fluid will help you determine what it is - if it's thick and dark / light and thin.
