PM sent
Reason for selling: Parting out my track car
For sale: Gearbox suit SR20 into AE86 $500
Item Description: Nissan R33 non turbo gearbox with SR20 bell housing, this box is shorter than an SR box when doing a conversion placing the shifter in a better position, it is also stronger
Item Condition: very good
For sale: HKS 2510, Adjustable HKS wastegate actuator, Jap tuned length SR20 manifold, braided water and oil feeds with speedflow fittings$1000
Item Description: HKS 2510 turbo done very little work and bought NEW, the turbo has a HKS adjustable wastegate actuator on it (currently set at 10psi), it is bolted too a Jap tuned length SR20 manifold. The turbo also has braided water and oil feed lines with speedflow fittings on them.
Item Condition: Perfect condition
For sale: TRUST oil cooler (approx 200H x 300L mm), lines and remote filter mount
$300
Item Description: Blue TRUST oil cooler, braided lines and speedflow fittings, remote filter mount
Item Condition: Good condition
For sale: 3" tailshaft to suit SR/CA conversion into AE86 or KE70
$200 ONO
Item Description: This tailshaft came from Bretts JDM Garage sponsored SRAE86 (normally $450 new)
For sale: GT4 Celica radiator with twin large thermos, temp switch built into radiator for AE86, perfect for SR20 conversion $100
Item Description: This radiator is to suit AE86, it has two large thermo fans in a plastic shroud, the temp switch is built into it and the relays and wiring is attached, there is also extra wiring for an over ride switch. The outlet in the top tank is on the passangers side and the outlet for the bottom tank is on the drivers side.
Item Condition: Great condition
STRUT BRACE - SOLD
INTERCOOLER AND PIPPING - SOLD
EXHAUST AND DUMP - SOLD
INJECTORS SOLD
CLUTCH SOLD
For sale: C's short shifter suit nissan g/box $100
Item Description: Short shifter too suit a Nissan gearbox
Item Condition: perfect
For sale: AE86 to SR20 engine wiring loom $100
Item Description: AE86 to SR20 engine wiring loom, this loom has a Z32 airflow meter plug 4 the airflow meter and has been minamalised some what
Contact: Brett 0433 191 205
Last edited by kaibeecee; 26th October 2010 at 04:58 PM. Reason: adding more parts, parts cheaper
PM sent
All PM's repley'd too,
Carnt understand why no one is keen on this strut brace
Strut brace SOLD
I'll take the tailshaft and the harness...please let me know through pm
thanks heath
ill have the oil cooler... pm me. im in ipshit..
hay what the size on the radiator???
