Results 1 to 7 of 7
Thread: O2 sensor, what type do i need?
    Daniel
    Queensland
    South side
    Default O2 sensor, what type do i need?
    Hey guys quick question, i have a 4agze in a ke70 and im trying to find out what o2 sensor to run. All i could find in the forums was a four wire o2 sensor. Is this all i need to say? whats the difference between two wire and four?
    Veteran biggo's Avatar
    Nick
    Noosa
    4 wires are heated. 2 wires are normal, toyota use single wires and they ground out thru the body/exhaust/headers/ground strap.
    if you dont have a fitting for your o2 sensor you can get whatever you want. otherwise get what you can fit on/in the fitting. Only 20v's had 4 wire o2's
    Anthony
    you should get a 4 wire sensor as this is what 4AGZE'S used.
    Daniel
    Queensland
    South side
    single wire it is!!! thanks for the reply
    Nick
    Noosa
    Forget i said anything, my 4agze bigport shitty aw11 only had a single wire.
    But seriously, it an 02, it will heat up eventually.
    Daniel
    Queensland
    South side
    oh true, no worries 4 wire it is then. Thanks for the reply!!!
    Anthony
    Yeah thats sort of true biggo. Depends on location. If you put a one-wire where a four-wire is meant to go, it will never get to temp...
  1. O2 sensor question
    By haveaparty in forum Technical - Questions
    Last Post: 2nd November 2012, 09:15 PM
  2. o2 Sensor wiring
    By shortround in forum Technical - Questions
    Last Post: 28th December 2009, 02:23 PM
  3. o2 sensor for adaptronic -
    By NIZLAH in forum Technical - Questions
    Last Post: 16th May 2009, 12:30 PM
  4. O2 Sensor Plate
    By jason in forum Technical - Questions
    Last Post: 11th March 2007, 08:57 PM
  5. o2 Sensor 4AGZE
    By SKREMN in forum Technical - Questions
    Last Post: 27th October 2006, 12:26 PM
