Results 1 to 10 of 14
Thread: rotary conversion
    Dan
    Wa
    Default rotary conversion
    hav a series 1 box and 12a r5 engine lying around and thinkin of doin naughty things to my 86
    has anyone here done it or hav info
    did rough measurement and should fit
    obviously need to make mounts for engine and box and get shaft fab up but yer any info appreciated
    Veteran driftke70's Avatar
    Ryan
    Buderim
    has been done, i was pretty much on track to do a 13bt but couldnt find any clean cuts for anything less than an arm and a leg, but from memory, if you use a 12a front housing, its heaps easier to mount, and if you use a s4 gear box, it should pretty much come out in the right place. A friend of mine recently completed a 12a conversion, I had pics but they are lost in my old pms, but there is one fellow floating around here somewhere, might have not made a new members ride on the new site but he had a pretty clean example.
    wheelfriends.wordpress.com
    Member SSD20V's Avatar
    Telly
    Inner West
    Seen one on youtube in Japan with a 20B Turbo,The thing absolutly ripped.
    Akio
    Mt Haruna
    Japan
    Dan
    Wa
    there's always one against rotors xero
    Dan
    Wa
    driftke70 :
    i am usin a 12a so should be easy enough to mount up.
    is the s4 jus a case of the shifter does not need modifying???
    Senior Member jet111's Avatar
    Mark
    Here is the youtube video of the 20B Sprinter...
    http://www.youtube.com/watch?v=VvYqqOig-ro
    Wait untill 1:49 for the good bit
    Kevin
    Queensland
    North Lakes
    i think the 20b is actually a left hand drive model
    Ryan
    Buderim
    he used a usdm shell for clearance issues,
    20b is largelly irrelevent to his question
    s4 is same as s5 and 6 in regards to gbox, but the rear housing is different.
    after rebuilding 2 stroke motorbikes you appreciate rotarys.
    Kevin
    Queensland
    North Lakes
    yeah sweet i think do it i love the rotary great motor u cant fault a 1.3 lt engine that can make that much power use to own one loved it and regret every day i sold it
  1. Rotary Powered ke70
    By rotaryrolla in forum KE70 / AE71 Owners Forums
    Last Post: 8th March 2010, 03:23 PM
  2. Rotary into T-18?
    By floody31 in forum Technical - Questions
    Last Post: 28th May 2008, 09:49 PM
  3. MX-5 Rotary
    By Klutch in forum Toyotas in the Media
    Last Post: 11th July 2007, 01:40 AM
  4. Rotary Conversion
    By Lewis in forum Technical - Questions
    Last Post: 12th June 2007, 10:38 PM
  5. rotary conversion info needed
    By CHAMP in forum General Topics (No Technical Questions)
    Last Post: 10th June 2007, 02:49 PM
