Results 1 to 10 of 11
Thread: Ke70 wiring diagram - help wiriing 4age into ke70
    Jon
    Durack
    Default Ke70 wiring diagram - help wiriing 4age into ke70
    Yes i have searched and no i have not found anything useful at all!
    can anyone help me with wiring up my 4age or a ke70 wiring diagram.
    Jon
    Durack
    frustration
    Veteran biggo's Avatar
    Nick
    Noosa
    There is not alot of wires needed, run the 2 12v ones to the coil that are already there and grab another 12v ign one and run that to a blade fuse holder. Use a relay, then get all your 12v's from the fuse box.
    Dave
    its to hard to explain in one post.
    you need to head over to club4age.net and get the wiring diagram and study it. there isnt much to it,
    -ign power the main injector/coil/everything wire (big orange wire usually)
    -power the ecu
    -ignition to the ecu
    - start signal to ecu
    done!
    where abouts are you located, if you are close i can come around and show you in right direction.
    - Blaise Pascal
    Veteran slide86's Avatar
    Huw
    Hills
    im wiring 3 4ages at the moment, they really arent that hard once you have got the hang of it.
    Dave has got it exactly right.
    Tell you what, when i go down to the workshop monday, ill take a heap of pics and make a thread to try and explain it all, then you can visually see what others are on about
    Jon
    Durack
    I'm a wiring noob.
    i have trawlled the internet and i couldnt find a wiring diagram for ke70 and i have the one for 4age.
    Dave would you be able to assist?
    Dave
    where do you live?
    - Blaise Pascal
    Jon
    Durack
    brisbane north
    Veteran Nikkojoe's Avatar
    Tom
    Don't really need a diagram for the ke70. There is a wiring guide I wrote which you shoul be able to find in the tech section.
    Tom
    The wiring guide I wrote is further down the page( though no one left my name to it :/). Ignition wires for engine looms are usually black/orange or black/red.
  1. 4age into ke70 wiring
    By Sprinter Freak in forum Sydney & NSW Events and Discussion
    Last Post: 28th November 2011, 03:17 PM
  2. KE70 & AE71 wiring diagram
    By KePanelVan in forum Technical - Questions
    Last Post: 11th August 2009, 11:49 AM
  3. 4age into KE70 wiring
    By ke70 xx in forum Adelaide & SA Events and Discussion
    Last Post: 8th May 2009, 12:40 AM
  4. ke70 wiring diagram
    By bigm in forum Technical - Questions
    Last Post: 24th December 2008, 08:44 PM
  5. jdm 4age wiring diagram
    By Rich_86 in forum Technical - Questions
    Last Post: 12th December 2007, 05:40 PM
