Results 1 to 4 of 4
Thread: oil coolers on N/A 4age worth it??
    Veteran shift_rook's Avatar
    SE Burbs
    Default oil coolers on N/A 4age worth it??
    hey guys yeah as the title asks.. i'm in the middle of quite a long build. just wondering whether it's worth getting an oil cooler for an na 4age?? any real benefits at all as the oil needs to be at a certain temp anyway... if i can get quite a large one is it worth it??
    alex
    if your thrashing the motor, the oil will rise above required temperatures. Hence, an oil cooler is used. If its for street and you dont think you'll be doing alot of high revs for long periods of time, then dont bother. But if you can get it really cheap, they look cool and increase your oil capacity...
    Veteran blair's Avatar
    Blair
    Sheldon
    get one with a thermostat
    SE Burbs
    yeah k, well yeah will have this for a few track days so may aswell.. thanks
  1. Replies: 6
    Last Post: 2nd May 2013, 12:35 AM
  2. oil coolers
    By slippry in forum Technical - Questions
    Last Post: 25th September 2008, 05:39 PM
  3. Oil coolers
    By eightsixboy in forum Technical - Questions
    Last Post: 19th October 2007, 02:35 PM
  4. oil coolers
    By D0R186 in forum Toyotas in the Media
    Last Post: 13th July 2007, 01:51 PM
  5. 20v oil coolers
    By Poobrown86 in forum Technical - Questions
    Last Post: 6th August 2005, 09:48 PM
