I did that when I put the short shifter in my T50.
ay all 86dc boys and girls
so a while back now i got a short shifter cs i think . the other day i was reading on here how bad they are and they shit them self after a bit of driving .
so with my car off the road for a while i rebuilt the shifter
1 remove gearbox boot cover
2 undo 4 bolts holding shifter in to the gearbox
3 there is a clip at the top of the shifter housing remove this clip
4 you will now be able to remove the stick from the housing
5 clean all parts with a rag
6 find a spring from a horn like i used cut down the spring and roll over shifter
7 pack housing with grease
8 place shifter back in postion
9 place clip back over housing
10 and bolt up again
i find this to take away a lot of play that shifter had before doing this
2 in the pink 1 in the stink
TRD ones seem to be HELLA noisy unless they're new
C's are pretty decent
this maybe why my second gear dont like it to much ....
lill bit noisy to
TRD ones don't have any dampening rubber in the shaft, so they get a bit noisy.
unless you're resting your knee on it while driving the centering springs will vibrate pretty badly.
C's are a little better, but they have a quicker throw than the TRD ones i think, which kills the boxes if you are flat shifting and that shit.
Any cheaper short-shifters available for T50's?
Want one to cut up..
