Results 1 to 3 of 3
Thread: 4agte turbo blowing smoke..
    Reeece
    Casula
    Default 4agte turbo blowing smoke..
    Hey guys ive got alittle problem going on with my t28 turbo blowing smoke sometimes.. I thought it was turbo seals but it doesnt happen all the time..
    If i were to leave the car there for 3 mins idling after warm it will start to pour out white smoke and then go away in 20 secs.. I am trying to work out if its to much oil in the sump for the oil return or seals are going.. the turbo drainline is 13mm . Noted turbo still boost sweet my last turbo also did this but not as often.. any ideas?
    Senior Member Simon-KE70's Avatar
    Simon
    start by taking the intake pipe off the turbo inlet and check for oil pools, if u have oil sitting there then turbo seals are shot,
    this might be a silly question but is the restrictor still in the oil feed on the turbo? assuming its ball bearing your turbo should have this restrictor. without it, the turbo see's too much oil pressure (bush bearing turbos dont need the restrictor)
    Reeece
    Casula
    its bush bearing sorry
  • Similar Threads
    1. my new 4agte blowing lots of white smoke
      By Nic19 in forum Technical - Questions
      Last Post: 14th December 2009, 06:46 AM
    2. 4AGZE blowing smoke
      By jamekins in forum Technical - Questions
      Last Post: 10th January 2009, 02:25 AM
    3. 86 blowing smoke?
      By simonster in forum Technical - Questions
      Last Post: 7th May 2008, 12:31 AM
    4. 4age blowing black smoke
      By deanoo in forum Technical - Questions
      Last Post: 19th January 2007, 07:01 PM
