Page 7 of 59 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 57 ... LastLast
Results 61 to 70 of 584
Thread: Wakarimasen
  1. #61
    Quote Originally Posted by 70XIN View Post
    If i wanted 2L and 240hp i would buy an SR and be $10k+ in a better position with a better gearbox and better torque
    Lol, werd! So much mention of 2L 7a's atm..personally i dnt see the use..my motor should be silly enough..if i wanted more id go straight to a beams or sr20ve
  • #62
    Seamus
    Milton
    okay.
    6-spd bellhousing is done. hopefully the gearbox will put together this weekend by a friend of mine
    basically all the parts for my motor are now here, so i hope to drop everything to the machinists as soon as they open
    buuuuuuuuuut none of it is going to go in unless i can find the parts required to ditch my power-steering
    so if any of you know someone who has a crossmember, steering rack, uni joint, and steering column ... please speak up
  • #63
    Veteran Robo86's Avatar
    Rob
    Hurry up
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  • #64
    Daniel
    GC Hinterland
    Really interested in how the 6 speed turns out, would like to make one for my gze. When I converted from PS to my quaife rack I used the PS column and a ma70 intermediate shaft. It isnt ideal and a pain to fit but its another idea if you get stuck, it works fine in the end.
  • #65
    Seamus
    Milton
    Okay, so because of the floods there's been a bit of a halt on progress - my gearbox guy can't put the box together for a few weeks .. so i might worry about that until after i've run the engine in.
    But my engine should be back by the end of the week, so i might have a running car in a week or two Will update with pics and stuff soon.
    ^ Clicky clicky!
  • #66
    Rob
    yayayayay!
    my corolla
    3274 5374 - Roy
  • #67
    Jon
    Durack
    I like this!
  • #68
    Seamus
    Milton
    Okay, so i got new extra-lock rack ends (from robo), and new poly rack bushes, tie rod ends, etc
    My question: How the f*ck do i install the D-shaped poly rack bush? I literally can't keep it compressed enough with my hands to get the bracket line up with the bolt hole. Is there something i have forgotten to do? Do i need some magical tool?
    ^ Clicky clicky!
  • #69
    Aaron
    i used longer bolts so i could start threading it before completely compressed it. and then tightened it down. after that i just cut off the excess thread
  • #70
    Veteran johl's Avatar
    Johl
    i used a g clamp. it is still a shit job but its do-able with the clamp
  • Page 7 of 59 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 57 ... LastLast
    Tags for this Thread
