Page 1 of 17 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 167
Thread: ke70 sr20 :)
    Senior Member corey70's Avatar
    Corey
    Default ke70 sr20 :)
    ok thought id start a build thread.
    well i bought a 82 ke70 completely stock for $500 it had gone through regency just befor i bought it.
    is a lil bit rough but will be fixed up later.
    started stripping it n took donk out
    a lil bit of paint (just aerosol can)
    drilled the holes on s13 cross member to fit in the rolla just had to make them oval cos didnt quite line up.
    so s13 crossmember is in
    purchased a s13 sr20 and gearbox fairly cheap just needs turbo n manifold,
    dummy fitted it almost perfect just needa do some more hammering of the firewall
    and so thats where im upto so far, will deff keep posting updates as i make progress, gotta wait for engine mounts to arrive and easyout the snapped manifold stud then put the hydrolic clutch n pedal box stuff in befor i put the engine in properly.
    corey.
    Corey
    my s13 cusco coilovers just arrived. ebay ftw
    Senior Member ke70 xx's Avatar
    Troy
    Woody
    thats dope. much rust?
    Quote Originally Posted by MINIHORSE View Post
    "if i ever get another 86 i think it will be a track only car"
    Tried that....failed.....you will too....its like sleeping next to a supermodel everynight and only getting to nail her 5 times a year
  • #4
    Corey
    nah only a couple little spots starting under boot lid but ill attack it b4 it gets bad, plus its in garage so wont get worse for now. a lil bit of surface rust here n there (bonet and passenger door) but both passenger doors are dented from previous owner.
  • #5
    Corey
    got my urethane engine mounts today
    also got given a ae71 pedal box so gotta get a clutch master cylinder then fit that up this weekend n gonna easyout snapped manifold stud then should hopefully get the motor in. oh and cut new gear selector hole as i fount out it sits bout 80mm further back than standard.
  • #6
    Veteran svenmate's Avatar
    Svenbot
    East
    soooo looking forward to seeing this completed!!
    where bouts in adelaide u from?
    AE71 Build Thread
  • #7
    Corey
    downsouth, woodcroft/morphettvale area. i cant wait till shes done either
  • #8
    Corey
    ok so iv been abit lazy buut iv got a lil update...
    stripped all the interior out, nmow on the hunt for a ae71 pedalbox.
    painted the engine bay
    picked up som s13 suspension goodies such as control arms brakes and hubs ect really cheap so redrilled castor rod holes and fitted them up.
    i definately needa get some flared guards and maybe shorter control arms as you can see this is wif 15x6.5 +10 offset.
    prob gonna get the steering rack in today and maybe new fuel lines either today or sometime this week.
  • #9
    Senior Member trueno85's Avatar
    Ayden
    Silverwater
    shit that's mint for 500!
  • #10
    Veteran shift_rook's Avatar
    SE Burbs
    that's gonna be crazy man, that was on of the things that put me off s13 front end
  • Page 1 of 17 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
    1. Sr20 ke70
      By GOODY in forum KE70 / AE71 Owners Forums
      Last Post: 3rd December 2009, 11:36 PM
    2. Sr20 KE70
      By sideways_ae86 in forum Technical - Questions
      Last Post: 1st August 2009, 02:20 AM
    3. SR20 into KE70
      By red_gem in forum Technical - Questions
      Last Post: 28th August 2008, 08:52 AM
    4. SR20 KE70
      By SRT070 in forum KE70 / AE71 Owners Forums
      Last Post: 13th August 2008, 01:21 AM
    5. ke70 sr20
      By adrianswood in forum Cars for Sale (Toyota Only)
      Last Post: 5th May 2008, 11:06 AM
