Page 5 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 41 to 50 of 167
Thread: ke70 sr20 :)
  1. #41
    Senior Member corey70's Avatar
    Corey
    Gone
    Joel
    Picton
    ^^^ neat! clean and simple. i like this THUMBS
  3. #43
    Corey
    got borgy back today wit mounts relocated and minispool fitted all ready to go
  4. #44
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    did u get the borgy shortened????, ive got the same diff and not getting it shortened so wondering what wheels u plan on runnin mate???
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
  5. #45
    Corey
    got bout 10mm taken off each side cos thats all they could safely take off without needing to get it resplined and heat treated.. its basically just the borgy centre with th tubes cut off and the ke ones welded on then skyline axles put inside ke tubes...
    doin it that way saved all the messing round of having to make a jig to get all the mounts perfect, this is how the toyoland one was done apparently.
    not sure wat wheels im gonna run yet but ill be gettin guards flared so it shouldnt matter to much
  6. #46
    Richard
    South Oakleigh
    fair enuf, yeah im not shortening mine, and plan to run 15 x 7 0 offset , working it out, that should put those rims with a 185/55/15, about 20 - 25mm out of the guard with out a flare, so ull be sweet with it being slightly shortened
    SQ ENGINEERING
    NCCE
  7. #47
    Calvin
    Kilsyth
    awesome idea with the diff. how do you go about getting the right bearing to fit onto the tubes and the seals?
    T18 in the build
  8. #48
    Corey
    no idea boss did it all i jst gave hom the 2 diffs and they did it
  9. #49
    Corey
    got diff in and bought some springs..
    in bout 2 weeks getting front and rear guards flared and firewall work done so motor will fit in nicely with room to change gearbox, clutch ect..
  10. #50
    Corey
    got some vs commo calipers on, hydro soon
  1. Sr20 ke70
    By GOODY in forum KE70 / AE71 Owners Forums
    Last Post: 3rd December 2009, 11:36 PM
  2. Sr20 KE70
    By sideways_ae86 in forum Technical - Questions
    Last Post: 1st August 2009, 02:20 AM
  3. SR20 into KE70
    By red_gem in forum Technical - Questions
    Last Post: 28th August 2008, 08:52 AM
  4. SR20 KE70
    By SRT070 in forum KE70 / AE71 Owners Forums
    Last Post: 13th August 2008, 01:21 AM
  5. ke70 sr20
    By adrianswood in forum Cars for Sale (Toyota Only)
    Last Post: 5th May 2008, 11:06 AM
