hey guys just bout to order a new head gasket for my ae101 4agze engine. i have called castle hill Toyota and they have the stock on for $90.80 or a 0.8mm trd one for $150 if i were to use the trd one would that bump the compression to high or will it be sweet. i am not turboin it nor do i plan to what you guys reckon
Drink & Drive Your A Bloody Idiot Drift & Slide & Your A Bloody Legend
well seeing that people run bigger pulleys just fine I would assume you could raise the compression without an issue if your using 98 RON fuel. Doing both on the other hand..
Keep in mind when you have a low compression engine to start off with losing some chamber volume with the gasket won't have as much of an effect. By the way thats way too much for the TRD gasket, see if greenline.jp still stock them
