Results 1 to 10 of 16
Thread: 3A to 4AGE Conversion
    Senior Member vivioman's Avatar
    Vernon
    Ellenbrook
    Default 3A to 4AGE Conversion
    Hi all,
    I have a 3A-U carby engine in my trueno and have talked to my mechanic regarding a conversion to 4AGE with fuel injection.
    He says the swap would be simple but wiring will be the most time consuming and complicated of the whole swap process.
    I just want your opinions about how true this is? I mean I have read many posts about swapping the 4AC to 4AGE and not one has mentioned about overly complicated wiring?
    Or could the complication be due to the conversion from carby to fuel injection?
    Just to add I am planning on a JDM RWD 4AGE + wiring loom + std ecu conversion.
    Thanks for helping our a noobie.
    4AGE AE86
    the swap will be no harder than from a 4ac...
    and if your planning on using a complete jap loom etc, it should be a piece of piss to do
    Vernon
    Ellenbrook
    Thanks mate.
    I'm also planning to use an external fuel pump vs an in tank fuel pump for the 4AGE.
    Anyone have any opinions about the pros and cons of external vs internal? I've been told that the conversion will be made easier by using an external pump.
  • #4
    Jonathan
    For a full conversion get a T50 gearbox also. But the K50 will probably work.
  • #5
    4AGE AE86
    the k50 will work Johnny, and that saves him having to change tailshaft
  • #6
    Vernon
    Ellenbrook
    Mine's a bit unique...it's an auto, so I am planning a manual conversion which prob will include the T50.
    Keep the information coming guys...
  • #7
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    well you might wanna change the diff ratios and no for the engine to be wired its like 4 wires to get the engine running a vl turbo fuel pump would make it so easy to do toymods has alot of info they would a big help for wiring questions
    the dyno pull to 300rwkw
  • #8
    Nathan
    Lilydale
    dont change the diff ratio!! its probably like...4.11 or something.
  • #9
    Jonathan
    It is 3.909:1
  • #10
    Veteran slydar's Avatar
    Dimitri
    get a whole jdm ae86 rwd engine with a loom, and then yes, its by far one of the simplest conversions ever.
  • Page 1 of 2 1 2 LastLast
    1. Replies: 4
      Last Post: 1st July 2012, 07:39 PM
    2. Is 3A dustcover plate (backing plate) the same as a 4AGE?
      By The_Jims in forum Technical - Questions
      Last Post: 13th November 2011, 07:33 PM
    3. 3a with 4ac head..?
      By bennyq in forum Technical - Questions
      Last Post: 8th October 2011, 03:18 PM
    4. 3a and 4a
      By ke.slider in forum General Topics (No Technical Questions)
      Last Post: 12th July 2010, 08:14 AM
    5. 4a-c trans onto 3a-u
      Last Post: 14th December 2009, 09:04 PM
