I'm looking at doing removing the booster on mine and a mates car, it's a fiddley job, need to choose the master based on brake piston bore sizes, you will have to go smaller master, so your pedal is not rock solid, but you will increase pedal travel, go bigger master and you get a harder pedal that needs less travel. make a plate to mount master to firewall etc, make an adjustable push rod, their is a thread floating round on toymods or rollaclub.
