hey todd can you pm me a pic of exactly you have with the rwd water setup please kthnxby
hey everyone, my brother has the following bits and pieces for sale.
Contact me on his behalf if you are interested.
1. Blacktop 20v Manual Loom
The loom is complete and in good condition.
$ 100 SOLD
2. Kaizen Garage distributor Alloy Plate
Brand spanking sexy alloy plate, ready to go on your 20v and make it faster.
$ 60
3. 16v Smallport head complete (with cam removed but included)
Off of my old AE101 engine that I spun a main bearing on.
Has one knackered exhaust manifold stud, needs to be helicoiled and fixed up.
Otherwise in good condition.
$ 100
4. 16v RWD JDM Bigport Intake manifold
Good working condition, TPS works but is a little off.
Complete with throttle body, fuel rail, and injectors. Everything needed to bolt on and work.
BONUS stainless intake included with pod filter to sit conveniently where the standard airbox used to sit.
$ 250
5. JDM bigport ECU
Removed from a stock zenki ae86 levin coupe. Works perfectly.
MAP SENSOR NOT INCLUDED
$ 100
6. RWD Water setup (incomplete)
This package includes a near new Water pump, rear water pump housing, rear water plate (the sensor housing on the rear of the head. Top outlet is also included.
Nothing else is included.
$ 80 SOLD
7. 16v Bigport Coil, Ignitor, Dissy and Leads
Everything needed on the ignition side of things for your 16v bigport rwd JDM conversion.
Includes good quality leads for super spark properties.
$ 120
8. Blacktop 20v Coil and Ignitor
As the title says, my brother has a blacktop 20v coil and ignitor surplus to his needs.
Items appear is fine working condition and are 'as removed' from his engine loom as he purchased it.
$ 70
9. RWD 16v 4AGE Timing covers, top and middle
Pretty self explanitory, have the top and middle timing belt covers available for sale.
Advantage over fwd ones are that the hole for the engine mount is not in the middle section.
$ 40 SOLD
10. 16v RWD AE86 4age bigport loom out of a zenki levin coupe
As pictured. most plugs are in fine condition with one or two being partially broken, not a real issue.
MAP SENSOR INCLUDED
ECU NOT INCLUDED!!!
Perfect match for the above ECU, can do a a package deal if buyer so desires.
$ 50 SOLD
There will be more added at a later date once we have removed the old engine and have a full garage of pieces.
All items are located in Perth. I can and will ship any parts to you at your expense.
Please send me a PM if interested in any of the parts and I will get back to you asap.
Photographs will be up in the next couple of days.
Regards,
Todd.
the dyno pull to 300rwkw
sure can pen15, give me a day or two to get the bits from my brothers house and i will send it through to you.
PM Sent
Rwd cooling parts will consist of front top outlet(minus sensor), rear plate(minus dash sensor) and water pump with back plate.
*NO bypass between the pump and top outlet is included.*
Loom is sold.
pictures of parts will be up shortly.
regardizzles, t-bag
pictures added,
Pen15 sorry for the delay, but the pictures will be up by this time tomorrow of what is included in the water setup.
Extra items added also.
more pictures added, and a few more items.
water parts sold!
bumpy
