sell me that bonnet! :p
*edits*
u fesbian!
Heh, must mean goldy is pretty mint too. Actually goldy is straighter than this just so you know
There was a 100% original gt apex trueno i could have got too, but thats 100% original and i wouldn't want to mess it up. It's still going to be street reg'ed and may be engineered (depending how things pan out). Still have some a/c shit, need a condenser....
In other news I've removed the engine out of goldy and just waiting for the new owner to pick up the shell. When that happens i'll be pulling out the 4age and bolting in the 4agte. In the mean time, I cleaned up the engine bay a little. Turned out ok
Also repainted the bootlid as the paint was mat white with a rough texture coat. Turned out ok for cans
Wanna start doing this next week! Also there will be things for sale shortly, have a lot of double up parts now that i don't need.
*edits*
u fesbian!
My 4agte hatch
http://www.ae86drivingclub.com.au/fo...ead.php?t=8583
my 70 wagon
http://www.ae86drivingclub.com.au/fo...ead.php?t=9525
my NA 86
http://www.ae86drivingclub.com.au/fo...s-2nd-sprinter
My Indonesian KE70 DX
http://www.ae86drivingclub.com.au/fo...nesian-KE70-DX
needs moar updatedness
Current Cars:
got a w58 on tuesday....
...and a loom to use with my new ecu (whenever i get it).
How's the current T50 in there now?
Best t50 i've driven (in a long time)
I'll only sell if there is a perfectly painted standard bonnet in colour code 041 in return
Cool, gimme a holla if ya selling hahaha
Did some work this arvo...
Rear guards were shitting me off because:
-They looked like ass
-They were too wide (my 8.5 -21's didn't quite fit properly, need 10's)
-The flare profile was kinda gay
Before:
They looked like this
So i took to it with a hammer and began trying to obtain the stock profile again. Few taps in and it was cracking like crazy, in which for a minute I thought the whole arch was fiber glass! Some massaging with pdr tools to pump the arch out again and the end result:
Now my 8 -5's fit better! Just need to get my lower springs to get the height nice. Ill get my welder out over the next few days and weld the cuts over and start smoothing out the imperfections
With some days off ive got now I started to get some work done
Got out early and started preparing the rear guards for welding. Had to clean up the stubborn bog (5mm thick) and original paint under it.
Then welded the outer edge in place! Was hard to weld because there was silicone used to seal up the cuts which could not be removed. In the end a few welds need to be re-done but all good
The other side I decided to get tig'd up but it was turning out worse than the mig due to the silicone. However its much cleaner in the cuts now so the mig might work better this time. Hopefully tomorrow i can get the remainder welded so I can start the filling!
Otherside welded!
Smoothed ready for minor filler!
