Yeah going to get another fitting put further down around where the cat would go (~1m).
Single wire O2 is at the dump
with that wideband o2 sensor they recommend (when i say they i mean AEM cos its the only one i've used!) putting it in place jus before the cat from memory...
could be wrong but i'm pretty sure thats what was written, and thats where we have it in my housemates GTR
mint build
NEAR MISS
ive never stumbled into this thread, why is that?
good work tho looks great!
it's a ninja!
Probs cause 75% of this thread is of my old gold shell. Should start a new thread but gotten a few pages in with this one!
smashing through the work tom
good to see.
get the adaptronic in and do some skids!
Slight update:
Painted the exhaust and fitted it all up.
Got adaptronic on Tuesday last week (dam public holiday).
Ordered some T piece fittings for water setup
Got some 5/8's oil hose and tried to fit it to the fitting on the sump and it wouldn't fit. Seems the nissan hose isn't internally braided since it's low pressure, and the hose i got is and wont stretch over. For now using the nissan hose with an adaptor to the remainder to the turbo drain. Also put heat shield sleeving on the drain hose near the manifold and dump area.
Modified my rwd water pipes to avoid knock sensor.
Removed the accessory section of the original 4age loom and got my donor smallport loom back.
Probs a few other things, might get some pics up soon.
Do it!
haha,
Gotta say mate, ive been dreaming of a GTE setup since that last drift outing... but I think Ill wait until I move and hence need to renew the engineering paperwork
Current Cars:
Got some pics of your modded sump and oil drain? I am changing mine around at the moment aswell!
Will get a pic for you tomorrow (well try to if i can get the camera down there!)
Pics:
Exhaust painted:
Modified water pipes:
Using a top water neck which has 2 threaded ports (used for a vac stem), so got an adaptor to fit my aftermarket temp sensor (no ugly cut top hose, less leaking points!).
And my oil drain location (note just using these clamps because i didn't have some when cutting the length of hose, just needed to stop the thing turning!)
