yes the side that has the 2 half bushes goes in the passenger side i.e attaches to diff, don't quite understand what you mean on the other bit though.. i have no pics
please read 3rd post
Last edited by charlie; 28th November 2010 at 10:48 PM. Reason: was pissed - didnt make sense
Alright, maybe this post will be a little more comprehensible.
Question #1
On the drivers side of the panhard rod there is a nut, bolt and a bush. I need to source the nut and bolt. Is my only option to call Toyota spare parts? I can't find an AE wreck and doubt Toyota would be able to help me out.
Question #2
On the drivers side of the panhard rod there is a metal sleeve - I have a new urethane bush, do I remove the metal sleeve and bin it then put the new bush in, or is the metal sleeve still needed?
Any help would be appreciated, I've run out of other work to do on the car and this is starting to really shit me
Last edited by charlie; 28th November 2010 at 10:44 PM. Reason: was pissed - didnt make sense
updated - now with funky pictures and less drunken rambling!
just got to bunnings or some place that sells bolts. buy a bolt the same diameter with matching nut. i like to use nyloc nuts just for extra extraness
make sure its long enough and HIGH TENSILE
doesnt have to be genuine, its just a nut and bolt
yeah will probably end up doing just that, reckon i'll find one that's only threaded half the way down the bolt? - loctite/nyloc for the win.
question #2 still remains: do I piss off that metal sleeve?
question #3
On the PASSENGER side what nut do I need - cant just grab one from bunnings as it goes onto this thing
take it to a suspention shop
not the answer I was looking for.
something more along the lines a pitch and gauge would be more on the money (not trying to be rude but I did ask some pretty specific questions)
question #2 and #3 still remain
yes you still need the sleeve. all you have to do is get a bolt that fits perfectly in that sleeve. it doesnt matter if its threaded all the way or half way. as long as its high tensile it will be strong enough.
and for that nut take one of the nuts off of your trailing arm bolts. pretty sure its the same size. just try it. if it works take that to bunnings with you when you get oyur other bolt. its like 12x1.25 or something
thanks h8chi - I'll take the nut off my trailing arm and stick it on to see if it's the same, then hit up bunnings tomorrow morning and purchase my high tensile bolt/nut and try to get something the same as my trailing arm nut
legend!
so THIS metal sleeve doesn't come out then? - just making sure your not be talking about the gold sleeve inside my new bushes
