Just put in a known calibrated one, its just 1/8 NPT.
Need a calibration table for the factory beams oil pressure sensor.
either that or if someone can point me in the right direction to an aftermarket one that i can get a table for.
also need a oil temp sensor that i can use as well
Yeah, the Haltechs normally use a GM 2wire sensor.
Power and Ground. Means that you get a cleaner ground reference. Toyota ones are dual wire too, the ECU ones anyway. The single wire stuff is the gauges.
Oh yeah, duh. For some reason i was thinking it was the same type as the water and oil temp senders. The 3 wire is power, ground, and a signal.
on the dry sump pump, andy it is set up right,for the oil pressure ,so dont change it.. also you do know that these motors oil pressure can be over 110 lbs or in kilopascals about 350 and up at high revs mine sits on 680 kph
