i seen this wen i picked up the 20v, pretty clean car,
So im over this for now and want to sell
83' ADM AE86
Bigport 4age
TRD copy extractors
2.5in exhaust
Timing belt and valve stem seals done
Exedy HD clutch
T series diff 4.11 ratio locked
Koni yellow front inserts adjustable
10kg coilover springs
cusco camber tops
t3 RCA's
urethane bushes all round almost
bigger rear swaybar
traction brackets
lovells rear springs
koni red adjustable rear shocks
corbeau drivers seat on bride rail
14x7 +1 enkei mesh
14x7.5 +-0 watanabes
j blood copy rear pods
streeter front lip
alloy radiator
Front and rear strut braces
Autometer water temp and oil pressure guages
Complete interior
The bad: there is some electrical issue, it doesnt always start first go, it could just be the injectors which is what i personally think. The seals need replacing again as they got covered in brake clean and went hard before i got it running. The rings arnt the best either. No RWC, but you can have the rest of the rego till 3/2011
EDIT 25/12/2010: It now has a rebuilt motor as the last one necked itself. I have receipts somewhere too. Even went that extra mile and put new ACL pistons in. Goes alright now.
Asking $6000
Maybe able to source a RWC for extra.
Car is located in Noosa QLD. PM me or phone 0400133158
pm sent
nicee. your selling up again?
i heard a rumor you wanted to swap for a 7mgte mx73 cressida, it just so happens i have one in stock at the moment....
NEAR MISS
