might seem silly for me ton ask dude but... why? did you round the bolt or something?
As title states, i know it can be done with other gearboxes but not sure it can be done with EVERY gearbox.
Also i realise that the correct amount would have to be poured in as there would be no way to tell how empty/full it is.
Cheers!
SuperFunHappySliders
SR's are ghey.
or your it would beeasier for you to do it through the top then to lay dwon on the ground and do it
Yes definitely, i fill every T50 this way. Fuck lying on the ground pumping the stuff in, just don't spill it on your carpet heh.
the one down side to the 6sp
every t50 ive tried to fill thru the shifter hole has only ever taken under 1 litre.
personally i wouldnt recommend it but if you do just take note of how much it takes
Works fine.
1.3 liters from memory.
Yeah, just undo the filler plug on the gearbox and fill until oil starts coming out of the filler hole.
^^^ this
you play halo?
add me GT: samnbhnc
go for 1.7 litres if you have to do it that way. not 1.3
