Results 1 to 10 of 16
Thread: Diffs - Paper gasket vs. Sealant
    Seamus
    Milton
    Default Diffs - Paper gasket vs. Sealant
    Just a quicky, keep the BS out please (if you feel the need, find some rope .. you know the rest..)
    I'm going to be sealing up my diff in a couple of days, i'm just wondering who has used what, and what leaked / didn't.
    I'm pretty sure with all my S-series diffs i used sealant, and never had a problem (as i was forced to replace the diff centres as regularly as oil-changes, so they never really even got the chance to leak..), but the cheap sealant shit we used in Robo86's diff DEFINITELY leaked.
    We have since used a paper gasket on his (with a bit of permatex red) and all seems to be purdy.
    Although i have been getting mixed opinions from the interwebs that, in this case, sealant is often the way to go and that paper gaskets have AIDS.
    So, what's the G-O?
    ** Please note, i am not interested in anything other than DIFF sealing **
    性交を愛する
    I have been informed this a good one.
    That said, I totally forgot to do anything with mine when I locked it..
    marvis.
    Jonathan
    There are lots of options. It is not critical.
    I used genuine Toyota Red Silicone today. I paid nothing for it. Any silicone will work good. Any leak will only be from the pinion seal or axle seals after that.
    The paper gasket is only good back in the factory, where both surfaces are new and clean. After that you need a liquid sealant.
    West
    Sealant 100%.
    I use the highest temp blue stuff to seal mine. I bought a caulking gun load of it. Works very well.
    Thats all my mechanic will use too, but his is grey. Must be even better.
    Site Supporter Javal's Avatar
    Josho
    I generally just use sealant on them. Sometimes they leak, sometimes they don't.
    The more expensive sealant generally works better.
    FYI, Lots of modern cars don't use gaskets for things like sumps and timing covers anymore - they just use specialized sealant - which i will be using along with gaskets when i reassemble my motor
    But, if the gasket is readily available and cheap - which, the masses might be keen to know how much and where you purchased it from - it is probably a better option.
    Also, ThreeBond > *
    Seamus
    Milton
    Ta kids, that pretty much sums it up for me, thanks
    Mt Macedon
    To add my 2c, I've always used whatever silicone sealant stuff my handyman dad had lying around at the time. It never leaked badly enough for me to notice before I was under there to change axles/centres anyway.
    Unless you had a massive pile of them I reckon a paper gasket would be a pain if you were regularly pulling your centre out.
    Kevin
    Queensland
    North Lakes
    i used form a gasket works great no leaks
    Veteran driftke70's Avatar
    Ryan
    Buderim
    selleys roof and gutter, not joking either
    wheelfriends.wordpress.com
    Kevin
    Queensland
    North Lakes
    yeah thats the grey stuff eh
  1. Paper cut-out/fold-up Hachi thread
    By randomskate in forum Offtopic Discussions
    Last Post: 14th September 2011, 06:07 PM
  2. Rock, Paper, Scissors... anyone?
    By squish_m8 in forum Offtopic Discussions
    Last Post: 18th May 2009, 01:29 PM
  3. Diffs
    By s-jyusan in forum Technical - Questions
    Last Post: 17th June 2006, 06:20 PM
  4. Evan in Saturday Drive Paper
    By fergo308 in forum General Topics (No Technical Questions)
    Last Post: 12th March 2006, 08:53 PM
