Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 31 to 40 of 84
Thread: CA/SR Conversions into AEs and KEs
  1. #31
    Senior Member worked's Avatar
    ed
    tas
    wynyard
    so lets look at positives and negatives and get them out so this can remain a tech article
    (add to what i've missed, i'm a fuckhead remember)
    kaibeecee mounts -
    retain ae crossmember
    retain all ae steering and susp components
    tunnel needs a light knock
    no modifying of steering shaft needed
    enginemounts required (use rb20 ones)
    s13-
    modify s13 crossmember to fit in
    no enginemounts required
    cheap!
    tunnel will require a tap as well
    custom gearbox crossmember needed
    steering shaft needs modifying
    s12 manual rack or restrictor in s13 ps system to make the steering not ridiculously light (you';d have to ask a powersteering guru what they do, i've heard of it done but never looked into it myself, regardless with s13 ps it feels dumb in a light ke)
    note: both setups will require engine and gearbox out to change clutch
    this is only to get the engine sitting in your engine bay
    you still need to sort:
    tailshaft
    diff
    fuel system
    radiator
    fmic and piping
    wiring (i'm having a chat with the bloke that makes these to get some shipped over to aus to have a try of, simple setup that has all yoru relays for power to the ecu)
    be good if we could find out measurements for tailshaft with sr and rb box with a certain diff, info on diffs that are readily available to be modified, what raditator to use, make a diagram for intercooler mounts etc
    the simpler we make it for others the more people start repowering shitbox 4kc corollas with sr20s
    NEAR MISS
  2. #32
    Veteran Skylar's Avatar
    Ken
    That thing totally looks expensive and a waste of money. So easy to wire CA/SR into whatever car, no need for fancy tyco relays.
  3. #33
    ed
    tas
    wynyard
    150 us, it is expensive but keeps it neat
    it's easy for people with experience to wire in SRs man, like the wiring diagram i posted up the top shows, but there had been some interest in these so here they are
    NEAR MISS
  4. #34
    Just on tailshafts Ed, ill measure mine when I pull it out in a week or two (got to get one made for the new build).
    For reference sake though, I have been told NOT CONFIRMED that if your using a RB20/30 box with SR bell housing on it and a 31 diff, you can use a 1982ish bluebird tailshaft.
  5. #35
    ed
    tas
    wynyard
    mint
    i reckon i'll go an rb20/30 box (didn't realise rb30 boxes were the same, sweet)
    i read on here somewhere that a bloke got his ke70 borgie diff tubes put on an r31 borg centre, with the axles shortened (if so i don't see why you could use two shorter side axles like you do matt)
    this would be handy to know if confirmed
    NEAR MISS
  6. #36
    Yeah, RB30 puts the shifter in the correct position as well. Easy enough to get too obviously. MX7 gearbox would be even better (VLT) im assuming they bolt up the same again but are probably stronger.
    I wonder what axles that guy would be using? I think passenger side 31 axles will still be too long. Would probably cost the same to do that to the diff as it would be to swap mounts on a 31 diff and shorten it, etc.
  7. #37
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I must of missed something, why an S12 rack in particular?
    now matt are you running front wheel offset wheels to make that fit?
  8. #38
    ed
    tas
    wynyard
    in one of my rants a few posts up i sorta outline it sam
    with the s13 powersteering rack it feels shit, either too light when hooked up or i found it odd with ps disconnected, s12 is a manual rack just like ke/ae, and fits in place of s13
    this said, lloyd smith ran an s13 ps rack in his 1uz ke70, just drained the fluid and says it feels good
    NEAR MISS
  9. #39
    S12 rack, direct bolt manual replacement for S13 powersteer rack. No need for power steer in the 86 and gives you more engine bay room due to not having pumps, etc.
    I usually have 15x8 -4 wheels up front. But for reference sake I have used 15x7 +19 aswell and also had my 15x10 -12's on there for a look. All fit, gaurd work required for the 8's and 10's obviosly.
  10. #40
    Endeavour Hills
    oh I see, how is the length of the rack though? the same as the s13 model?
  1. sr/ca conversion kit
    By stixy in forum General Topics (No Technical Questions)
    Last Post: 28th July 2012, 01:56 AM
  2. workshops doing sr 20 conversions
    By aeadzy86 in forum General Topics (No Technical Questions)
    Last Post: 9th March 2010, 06:59 PM
  3. VIC- Random parts (s13, ca/sr)
    By julzy in forum Car Parts For Sale
    Last Post: 6th August 2009, 05:44 PM
  4. SR,CA,RB owners look here
    By bigm in forum Technical - Questions
    Last Post: 7th May 2009, 09:01 PM
  5. for all u people with sr conversions!!!
    By Fozz in forum Technical - Questions
    Last Post: 14th April 2009, 12:31 PM
