Results 1 to 6 of 6
Thread: ke70 4kc prob
    Default ke70 4kc prob
    4kc lying up for 8 mths..got her goin.new plugs,fresh juice,leads new,sprayed shot of carb cleaner etc but still very lumpy at idle,wnt tik over properly,,,clears out wen u give her a gud dig of throttle but bak to lumpy/like missing on 1 cylinder wen low revs..clears wen i spray carb cleaner 4 few seconds...cnt figure it out..new inline filter,petrol is clean...wtf
    Scammer, DO NOT BUY FROM ME!
    check the timing
    as has been said before, they only need a couple of things so do a process of elimination
    check each cylinder has a strong spark
    check its getting fuel and air
    if it has these 3 then really it should run
    Jonathan
    If the motor clears and runs nice when you spray the carb cleaner around the outside of the manifolds, then that means you have a air leak. Either plug up your leaking hose, or get a new manifold gasket.
  • #4
    whipped off carb,exhaust and intake manifolds...new bolts and gasket sealer...cleand carb best i cudand put her bak 2gether...still missing tho,like a bad lead but ther all new..i can defo hear a miss especially standin behind the car,but all leads seem to hav gud spark..she tries to clear out wen driving now and again but she jus cant do it..wot shud timing b set at does ne1 know?
  • #5
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    advance 4~ worked pretty good for my 4ks. it might work for you or you might want to churn it out all the way advance and then turn it back untill it stops pinging.( what most guys on here would do)
    FTP.
  • #6
    Jonathan
    Check the compression.
    Get new points.
  • Similar Threads
    1. wrecking xx ke70 5spd 4kc
      By wide s13 in forum Car Parts For Sale
      Last Post: 27th June 2010, 05:10 PM
    2. Replies: 5
      Last Post: 17th April 2009, 12:47 AM
    3. Ke70 4kc piston dead?
      By AE86R in forum Technical - Questions
      Last Post: 23rd March 2009, 07:57 PM
