QFM HPX Fitted to VL Commodore!
QFM A1RM Fitted to Toyota JZX100 Turbo Chaser! (Different one!)
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
QFM HPX Fitted to Toyota JZX100 Turbo Chaser! (Different one again!)
A1RM up to the task in Rally and Race on 242mm Standard Rotors!
fitted the a1rm to the rear with new slotted rotors to my car (jdm 86) yesterday. holy flurking shnite, they are good! looking forward to a set for the front. really recommended guys.
QFM A1RM Fitted to JZA80 Supra!
*** Use of A1RM pads in a street-only car! ***
We'd like to clear the air on an issue that has been brought to our attention. Just recently we've had a customer query us about rotor wear when using the A1RM in their road car. The customer was running A1RM in his daily, which albeit driven hard, was only used to drive to and from work, and the occasional run over the hills. The customer got 15,000 km from his rotors (which admittedly had already been machined once) and the pads.
Where this has caused some unrest is that they were very expensive two piece rotors, and so is up for new rotors at substantial cost, so in light of all this, I feel it is necessary to clear a few issues:
- The A1RM is a street/track cross over pad. Even though it is 100% streetable (cold bite is substantial, generally noise and dust are low enough), it is a pad capable of light track work (similar to a Project Mu HC+ or Ferodo DS2500), and thus will had some drawbacks when being used only in a street only driven car. If you're using the A1RM in your road car because you'd like the ultimate in street brakes, be prepared to change rotors sooner than you would with a regular street only pad.
- The pad below A1RM, the HPX, is a Bendix Ultimate equivalent in terms of performance, so is more than enough for most hard street driven cars. Because it's also very low dust and rotor wear, we supply them as a direct trade servicing pad to a local QLD Ford dealer for use in Falcon's and turbo Territories that use the C5 PBR caliper. Average pad life on those cars with the HPX is about 45-50k kms with low rotor wear.
- A rotor life of 15,000 k's on an already machined pair of rotors (so maybe 20-25,000 k's on new rotors) is fairly good for a pad with the performance of the A1RM. Equivalent pads with the same performance will be no better than this.
The A1RM gets a very good wrap because of it's price/performance ratio, and if you take your car to the track to do some light club springs or circuit work, and accept that brakes will wear out quicker using performance items, then it's still the perfect compromise. If you don't do any track work at all, then probably best to stick to the HPX.
Personally, I run the A1RM in both my rally car, and road car, and don't have an issue with it in either. Additionally, we're also well aware of road cars that have gotten 25,000-30,000 (about 1 year) and a couple of track days out of rotors clamped by A1RM, so the wear will vary with individual vehicles and applications.
Any further questions or dramas please do not hesitate to contact us direct on 1300 884 836.
Regards,
Greg
QFM A1RM Fitted to JZX100 Turbo!
QFM A1RM Fitted to Nissan 300ZX Twin Turbo!
QFM A1RM Fitted to Mazda BA Astina!
No link available, sent via PM!
