sounds different, you seem to be some insane stuff, you planning on trying it??
is any 1 running just out board injection .meaning that the injectors are out past the butterflies ,and is the idle just as good as inboard
doubt it'd be much good for idle, have you thought about running both ie. inboard shuts off over certain revs?
^^^^ very doable
you play halo?
add me GT: samnbhnc
isnt it called stand off injectors?
there are some pretty sweet videos on youtube of cars that have it.
something like thiswould be pretty sweet, with the standard injectors working down low and the stand off ones working at high throttle positions.
i think the main drama is at low throttle openings if you are squirting fuel straight at the butterfly it wont work so great. but when the throttle is 100% open its just a flat disc it needs to get past.
- Blaise Pascal
