Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: xris's ke70
    Member KE70xris's Avatar
    Sep 2010
    Neil
    Taylors Lakes
    Default xris's ke70
    Blew my old KE70's engine up so i bought this new one. comp tested it before buying to make sure it was ok pulled 170,170,170,170
    Had some rear damage when i bought it and came with a spare rear qtr and was pretty much stock (wouldnt start with a key and looked to have been left outside for at least a year in the dandenongs)
    So first thing i did was clean the crap out of it and remove the million leaves that were in all the cracks.
    We then replaced the rear qtr and ive fixed all the wiring issues (stripped my old ke and swapped looms and all plugs across) I then stripped the extractors, exhaust, front lower control arms, knuckles, steering arms, suspension and swapped it over, we put in some Peugot rear struts and AU ford rear springs (fronts are corona struts, brakes, lca's). This time i wrapped the extractors in heat wrap to try and seperate alittle heat from the intake (as it sits on the extractors. Purchased some new fender mirrors and some Work 14x6.5 +20? wheels fitted some 165/65/14's to them and had my brother modify the guards to fit them.
    You might notice that the front end has alot of camber well we run Primal Garage and at Primal we like to do things ourselves so we modded up the lca to be 43mm longer, lengthened the steering arms 40mm, and modified the corona knuckles for more lock. So now i have so much lock its rediculas to drift with. before i could only hold a shallow drift before hitting the limits of lock now i can easily pull off 90degree slides, the car is now so much fun to drive.
    Heres a pic of the old engine bay
    List of Mods
    4kc 1299cc
    Modified Airbox
    Pacemaker extractors (heat wrapped)
    2 1/4" exhaust
    New NGK plugs
    new leads
    15degrees timing
    Modified Corona LCA
    Modified Corona Knuckles
    Corona front struts with chopped springs
    Munroe Peugot Shocks
    Ford AU Springs (chopped)
    Primal front strut brace
    Locked Diff
    Work ??? 14x6.5 +?? front 165/65/14
    Eagle Racing 14x6 +10 rear 175/65/14
    Fender Mirrors
    Bride Zeta with custom Primal rail
    OMP Dished wheel
    300mm Dildo gearknob
    On order
    AJPS Madhouse Chin Spoiler
    Soon to be resprayed
    Looking for some 14x8 -/0 ~ wheels for the back so it sits flush. going to purchase a 20mm bolt on spacer for the time so it doesnt look so aids..
    Sep 2010
    Neil
    Taylors Lakes
    New wheels arrived. painted them all up(all the same colour), painted the brakes and put them back on. Madhouse lip arrived and test fitted it up, next paint....
    Aug 2010
    Sutho Shire
    looking good,why respray?just do the boot to suit,looks real good
    Nov 2009
    Eastern Suburbs
    looks boss dude
    Senior Member myke90's Avatar
    Michael
    Southside Brisbane
    love the rims mate! looking good!
    ACT
    Compton
    glad to see the rims landed safe and sound.looking sweet mate!
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    looks pretty thug how it is.
    quit hatin get bakin!
    Nov 2009
    Eastern Suburbs
    agreed joe
    Nov 2010
    Jay
    what mirrors are those they look the goods
    Calvin
    Kilsyth
    that airbox mod will be sucking in nice hot air heated by the exhaust below it
    T18 in the build
