Page 1 of 18 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 174
Thread: Building a 7age.
    Senior Member Drift_Donkey's Avatar
    Byron
    Default Building a 7age.
    Hey Guys, I didn't do this write up! But I did find it very interesting and would be pretty helpful with building a 7age. If I'm not allowed to post this up, feel free to delete it
    Parts required
    PartsCost
    4AGE engine(you should have one of these!)
    late 7AFE engine with metal head gasket (low mileage import from Japan are now easily available, mine still had original honing marks in the cylinder bores and was in very good condition) (from an Avensis I think)300
    Brown injectors from 1985 Celica GT(3SGE engine)50
    Adjustable cam pulleys (piper cams)150
    Timing belt (Porsche 944 1986) there are two belts listed the one required is the timing belt not the countershaft belt11
    212mm clutch AE92 corolla GTI 1992100
    3/4inch water hose about 5cmCheap
    It is good to have a manual with you for torque settings and detailed information on the individual jobs you will undertake.
    Stage one - remove 4age
    Work methodically around the engine removing bolts and wires, label anything you don't know or may confuse you if you forget.
    Return removed bolts to their holes (this is because some bolts are made to be tightened up harder than others which just snap! I learnt the hard way so you don't have to! More on this later)
    Remove radiator for space
    It is the lower 17mm nut on the engine mount, which needs to be removed (the hidden one which is awkward to access) this needs to be undone not the top one!
    I removed the sandwich plate behind the oil filter because it is easier to access than the oil line (to the oil cooler) and is the same as the one on 7AFE wrap in a plastic bag and check the seal has not fallen off the back.
    Cable tie the wiring looms and oil cooler pipes out of the way in the engine bay
    Lift out engine using the hooks on the top and an engine crane
    Stage 2 - building 7AGE
    Again work methodically around the engine finishing each area properly so you don't forget anything
    Strip down 4age engine you need everything apart from the block
    Leave intake manifold connected to the head, camshafts must be removed to access head bolts, take care to note the loosening pattern and orientation of camshaft bearing caps - see manual
    When removing the head remember to loosen the bolts in the correct pattern - see manual
    When removing parts especially the engine mounts take care to return the nuts and bolts to their holes so you know which are used for what and what holes on the block are utilised (more on this later)
    Use two nuts locked against each other to remove studs then return them finger tight to their original holes.
    Strip down 7AFE engine only, the bottom end is required so remove all other mounts, timing gear etc
    When removing the head remember to loosen the bolts in the correct pattern and leave them in the head in their original positions so you can make sure the same ones go back in the same holes later on
    Take care with the head gasket it should be a nice 2 layer metal one (if it isn't order this from Toyota)
    Clean head and block mating surfaces I used some emery paper and a Hoover to Hoover out all the dust created!! Clean the head gasket
    Bolt 4AGE head on to 7AFE block using the original 7AFE head bolts, each back to their original positions. use correct tightening pattern first all to 29nm then each through a further 90 degrees then all again through a further 90dgrees, see manual
    Return camshafts and tighten camshaft bearing caps in the correct order facing the correct way (they are each labelled on the top with an arrow and number like E1 which stands for exhaust side first bearing cap (the closest to the cam pulley) E2, E3, I1, I2, I for inlet side etc)
    You may need to clean them to see the markings add some engine oil to all the bearing surfaces before tightening the bearing caps. Return cam covers, bearing caps and cam covers to 13nm
    Transfer the water pump and all its pipe work it should all come off 4AGE as one piece with three 12mm (15nm) bolts on the front of the block, use the seal from the 7AFE pump as it is probably a bit newer, clean the mating faces. The pipe support bracket on the side of the engine block cannot be used I just left it as it seemed secure enough you could make a simple bracket to hold it.
    The water pump to head pipe needs to be extended, just cut it in half put the 3/4inch hose over, you only need about 5cm and clamp with two jubilee clips.
    Fit adjustable timing pulleys, firstly mark them against the original pullys for the original timing marks. make marks on the new pulleys by drilling a shallow 3mm hole where the timing mark should be (the same place and fashion as on the original 4AGE ones (the small indent on the rim) check the right one is on the right side as they are different see manual for orientation
    Fit the lower timing belt pulley from the 4AGE engine to the crankshaft
    Line all the timing marks up then fit Porsche 944 timing belt, re adjust the tensioner to take up the slack
    The lower timing belt cover from 4AGE needs to be modified to fit, look at it from the back there will be a second outer circle around the hole for the crankshaft just file it out to this outer hole and it will fit nicely
    You will notice the camshaft pulley timing marks do no line up correctly when the lower pulley mark is lined up. Use the adjustment on the cam pulleys to retard each camshaft by approximately 3-4 degrees to so it all lines up nicely
    The middle timing belt cover will no longer fit
    On to the back of the engine
    Remove 4AGE flywheel and bell housing backing plate, clean the backing plate and transfer it to the 7A block (9nm)
    Bolt on the 7AFE flywheel using the correct bolt pattern (74nm)
    Bolt on your new 212mm clutch (a nice little upgrade) (19nm)
    On to the left hand side
    Check which holes are used by looking at the 4AGE block:
    Run through these with a thread tap!!! If you don't what will happen tome will happen to you! I used a different bolt, which just sheared off in my block because it was not intended for that much torque and the thread was too stiff!! Long!
    Transfer all the studs and fit the engine mount and alternator bracket, the lower gearbox mounts can no longer be used as they don't line up chuck them away.
    The intake manifold support needs to be extended I did this by making a simple extension bracket at the top
    You might as well fit alternator and belt
    The right-hand side
    Run through these with a thread tap!!! If you don't what will happen to me will happen to you! I used a different bolt, which just sheared off in my block because it was not intended for that much torque and the thread was too stiff!! Long!
    Transfer all the studs and fit the engine mount, the lower gearbox mounts can no longer be used as they don't line up chuck them away. Fit the block earth lead and starter motor loom clip which should have come off with the engine mount from 4AGE
    Remove the oil filter sandwich plate
    You might as well fit the starter motor
    Top
    Change injectors take care not to damage the fragile seals, in fact you should replace upper and lower seals as they are probably very worn out! When I replaced my injector lower seals I thought the guy gave me the wrong part it looked so different to the deformed old thing I took out!
    A tab must be cut off the Celica injectors try one on a injector plug and you will see which tab needs cutting use a sharp knife then the plug will fit like normal
    Stage 3 - return engine
    Drop it back in you will have to wiggle it around to get it on the lay shaft from the gearbox jack the gearbox up this helps
    Refit all bolt and wires work methodically around the engine and make sure everything is done before moving to the next area
    Fit the oil cooler sandwich plate which you wrapped in plastic and a new oil filter
    Check the oil line up the distributor (see manual)
    Fire it up! Set the ignition timing I found the original marks on the lower timing cover not to line up it shows about 3 degrees too much advance so take this into account when you set the timing (again i learnt the hard way experiencing detonation after 7000RPM !)
    Experience a 4age with a killer torque band, the rear tyres have no chance!!! I was a very happy bunny indeed
    ps it doesnt like being reved over 7k and power drops off at about 6700 so this is where i have set my shift light, it pulls hard untill then.
    If anyone has any questions or queries post them and I will try and edit this post to incorporate the answers!
    after 300+ miles now the engine hasnt blown up so im pretty chuffed, and after much testing against a close friend last night i can safley say the engine has lost no pace despite the reduced redline and changing gear early, (this was a fear of mine because there is normally always a trade off) the new torque band just pulls it through the gears, i never thought id say this but torque really is very exciting too on the street adding a whole new dimension to the corolla!
    calculations for compression ratio:
    compression ratio = swept volume + clearance volume / clearance volume
    clearance volume = head gasket thickness + piston to block deck clearance + combution chamber volume + dish in piston
    swept volume = cross sectional area of bore x stroke - dish in piston
    values for 7AGE
    head gasket thickness 0.266mm (when compressed) (based on when a 0.8 3 layer TRD metal headgasket is compressed it becomes 0.4mm (taken from club4ag.com) so 2/3 of this value is taken (because this was a two layer metal head gasket)
    piston to clyinder deck clearance on 7AFE block 0.3mm (taken from club4ag.com)
    combustion chamber volume for 4AGE head 39cc (taken from club4ag.com)
    dish in piston 73mm diameter with 3mm depth (aproximate value i would apreciate a more acurate measurment)
    bore and stroke = 81 and 85.5mm
    so clearance volume = (values changed to cm for continuity)
    = [ pi 8.1 ^2 / 4 x 0.0266 ] + [ pi 8.1 ^2 / 4 x 0.03 ] + [ 39 ] +[ pi 7.3 ^2 / 4 x 0.3 ]
    = 1.3707 + 1.5459 + 39 + 12.5562
    = 54.4728
    = pi 8.1 ^2 /4 x 8.55 - 12.5562
    = 428.025
    so
    = 428.025 + 54.4728 / 54.4728
    = 8.86
    so as my head has been skimmed (but i dont know to what thickness)
    i would guess the compression ratio to be around 9:1
    ps values used were mainly found on club 4age and cannot be varified i have tried to be acurate please point out any mistakes you find in my working!
    conclusion extra head skimming or late small port pistons would improve the compression ratio and power output
    Quote Originally Posted by marvis View Post
    I also like sportmaxx and incorrectly placed/applied hangrings.
    Seamus
    Milton
    That's definitely a good article, but from first-hand experience i can add a few things
    -Flywheel: You can also use a 4AC flywheel (200mm clutches) or better yet, the 7AFE flywheel (can use 200 OR 212mm clutches)
    -Injectors: Do not buy the injectors listed in this article. In Robo86's case, we put the car on the dyno, and standard bigport 4AGE injectors flowed more than enough fuel on a standard 4AGE computer etc. Infact it was still running a bit on the rich side.
    -Timing belt: We ended up using a "t107" belt, 924 porsche
    Senior Member davidgarratt's Avatar
    david
    morayfield
    So does the 4ac flywheel fit on any 7afe crank ie a ae93 ?
    自動車変質者 - Just about sums me up!!!
    Nov 2010
    kim
    Shinjuku-ku
    Japan
    yes it does. both are 6 bolt.
    although i would use a 212mm flywheel...
    david
    morayfield
    Thats cool I didn't really look when I did my 4ac - 4age swap if its as easy as it says might give it a go cos iv got most of it sitting there, but one more question if I may can I use 20mm hole 4age pistons?
    Seamus
    Milton
    Yep, 7A pistons/rods are 20mm.
    david
    morayfield
    Looks like I might build a 7age to replace my tired 4age thanks for the helpful info
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    from what my conversion has taught me in this article it dosnt mention the spigot bearing witch could spell trouble if you forget it.
    the part number i gave repco is 6001-rs they normally stock them but here is a helpful link full of info on them
    70XIN what was the cost of the Porsche timing belt do you remember?
    the dyno pull to 300rwkw
    Veteran Nikkojoe's Avatar
    Tom
    With regards to the hose clamped over the bypass pipe, couldn't you just use a rwd 4ac one? They are longer than the rwd 4age (like 5-10mm from memory).
    7a bypass pipe should be 70mm long...
    the spacer required on the top outlet for the bypass pipe to line up with the waterpump should be 10mm...
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. building need parts..
    By josh.. in forum Cars or Parts Wanted
    Last Post: 31st March 2011, 09:55 PM
  3. Building a cage
    By driftke70 in forum Technical - Questions
    Last Post: 27th January 2007, 04:16 PM
  4. Building 4age
    By works510 in forum Technical - Questions
    Last Post: 6th March 2006, 05:14 PM
