Page 5 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 41 to 50 of 174
Thread: Building a 7age.
  1. #41
    Dec 2010
    Cal
    bang on pat
  2. #42
    Quote Originally Posted by 70XIN View Post
    Okay mine is kinda basic, not quite as crazy as delazy's monster. Should be fun though!
    Mine is far from a monster..lol..
  3. #43
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    boss doesn't have vvt its been removed but has toda adjustable cam gears
    the dyno pull to 300rwkw
  4. #44
    Quote Originally Posted by pen15 View Post
    That explains it then, one would assume its been simply reset via the cam gears...
    Was the initial method i took, but seeing as the oil pump is coming off to replace the ae111 item with a ae101 pump i thought i might aswell change to the modified timing gear also...
  5. #45
    User fantapants's Avatar
    Pat
    yeah if you dont use vvt then you dont need a recut keyway, simply play with adjustable cam wheels.
    06/07/2011
  6. #46
    性交を愛する
    Worth paying an extra ~$200 for ARP head bolts? Or just get stock toyota? Will definitely use them for flywheel though..
  7. #47
    Seamus
    Milton
    New toyota (or even non-genuine) head-bolts will be fine.
    ^ Clicky clicky!
  8. #48
    Mathew
    Sutho Shire
    i just re used my old second hand head bolts there is no need for anything stronger
  9. #49
    Senior Member Adsie's Avatar
    Adam
    Birkdale
    Why replace the flywheel bolts?
  10. #50
    Akio
    Mt Haruna
    Japan
    because once they are tightened and loosened they lose some integrity and may sheer.
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. building need parts..
    By josh.. in forum Cars or Parts Wanted
    Last Post: 31st March 2011, 09:55 PM
  3. Building a cage
    By driftke70 in forum Technical - Questions
    Last Post: 27th January 2007, 04:16 PM
  4. Building 4age
    By works510 in forum Technical - Questions
    Last Post: 6th March 2006, 05:14 PM
