sorry im only new hear and mabye im not just looking in the right spot but i would think you would have somthing about wiring a 4age in this because it is one of the most asked about questions
This is an index of the various threads set aside for questions related to certain topics. In due time if it works out and I could be bothered this will be broken down into sub-sections.
This is very much a work in progress and if you wish to add a comment or have a suggestion then feel free to make a post.
No new threads are to be made if it fits under one of these topics mentioned below:
ENGINE TROUBLESHOOTING
- Universal something is wrong with the running of my engine: All engine problems and fault finding here
BODY BRACING / SUSPENSION / STEERING
- Choosing Body braces: how to tell which braces actually brace and what's rubbish
- Everything about steering racks
- Pan-hard bar customisation, adjustment, different bushes and results
- Watts and WOB link suspension
- Lock spacers, custom racks and custom steering arms: Anything to do with more lock here, no coilover questions
- AE and KE FRONT coilover questions- anything to do with the use and fitment of FRONT coil-overs
- AE and KE REAR coilover questions- anything to do with the use and fitment of REAR coil-overs
- ae86,ae71,ke70 cambertops
- Larger OEM rear swaybar from another model for an ae86
ENGINE CONVERSIONS AND MODS
- 4age + 7AFE to a "7AGE" hybrid #1:
- 4age + 7AFE to a "7AGE" hybrid #2:
- Installing a 20V 4AGE into rear wheel drive:
- Universal 3sge (inc Beams) into AE/KE thread: all conversion questions go here
- Intake and filter options for quad throttles
- Index of clutches and flywheels available for 3SGE Engines
- AE71 auto to manual conversion
- Different length accelerator cables available:
- Universal CA/SR into AE/KE thread: all conversion questions go here
- F20C conversions
- All about oil coolers
- Mods to increase power in a 20V
- Running in a new engines
- Starter motor clearence with 16 & 20V 4age engines
- Blacktop 20 valve 4age, Interference engine?
- All Holden/Buick 3.8L into AE/KE questions
- Hooking up a 4age 16v RWD cooling system
- 16V Vs 20V gaskets
- Stiffer 4A Engine mounts
- Running a 4age engine on carbs
GEARBOX
- Adapting a Supra Gearbox to a 4AGE / 7A
- Adapting a Aisin AZ6 Gearbox to a 4AGE / 7A
- Speedo drive mechinisms
EXHAUST
- Stepped headers
WIRING AND ECU's
- Which aftermarket ECU to choose?
- Wiring connection of the firewall loom to engine in an ae86
- Wiring connection of the firewall loom to engine in a KE70
DIFF CONVERSIONS
- F series diff questions (articles section)
- F series diff centers for drift
- IRS into an AE/KE
- R31 Skyline and Pintara diff conversions
- Very easy to userstand guide on how a diff works:
FUEL
- Which lift pump?
BODY
- Fiberglass panels
OTHER STUFF
- Options of fitting an ae86 pedal box to a KE70
- Modding a KE70 pedal box for hydraulic use:
they have it all here including pictures from prep to finish, you just need to hang around a little bit longer.
NOTED
