Yes.
did you put a fresh batch of fuel in?
Yes.
I'd rather have an '86 than a girlfriend.
Hey guys started to pull my engine apart today for fun and I noticed that in the valley where the spark plugs are the is some corrosion is this something of concern or just abit of moisture getting in over the years.
MOPAR or no car!
ok took in all the info, and after a small drive turned off again... i pulled over and poped hood and found loose conection that fell under the battery looked like a sensor, chased up any open line and put them to gether, also swaped som lines under the air box thing and car hasnt stalled in 3 days... wraped but idles at about 1300 and dosnt really change with the idle adjustor.. but still thanks guys
muzzers dont know bout my kpgc10
car: adm ae86
engine: smallport 16v 4age
problem: my engine doesnt have a oil pressure sender hooked up to the dash. is it just a 1 wire thing, or multiple wires? its a strange looking connection on the top of the sender so it has be confused. how would i go about connecting a wire to the sender? just a normal Y shaped connector crimped on the wire and pushed on the end of the sender?
yea man 1 wire, switches earth to the light, and its yellow black or yellow green on your cluster (trace the metal strips on back of cluster)
sorry thats for a ke 70 cluster, bp 4 age, i doubt the clutster colour would be differ but they might
Car: AE71
Enigine: 16V BP 4AGE
Problem: Having dizzy issues; it spat the metal needle off the rotor button the other day, it bent one of the pins in the dizzy cap and there was a lot of broken and brittle plastic in the cap as well. cleaned it out and straighted the bent pin, bought a new button, put it in and it fired straight up, it ran sweet. Went to start it the next day and now has no spark?? im stumped. I have a coil pack from a daewoo would it be worth while wiring this up? as the car is running a razorback ecu.
due to people not getting enough replies to their requests I am going to close this section and let people start new threads as per previously.
