Results 1 to 10 of 13
Thread: Removing Dash
    Junior Member kezza's Avatar
    Kezza
    Default Removing Dash
    Can anyone tell me if there are any tricks to removing the dash. I've removed the lower half but the top will not come out.
    Cheers, Kez
    ke or ae?
    if its a ke there will be bolts and screws to take out everywhere.. the main ones i can remember are 1 or 2 on each side. and 5 or 6 down the middle underneath.. atached to a cross bar. just pull on it iff its attached in spots then check around for screws/bolts.
    im sure ae wont be too much different.
    dont forget the screws behind the a/c adjuster
    Rian
    guessing by your pics its ae86 there are 2 bolts behind the top 2 little square vents and i think one near the clock
    Kezza
    Yeah sorry AE.
    These are the bolt I'v found thanks to rich_86. But I can't find the other 1 next to the square vent your talking about.
    Is there any other bolts. The dash still feels pretty soild in there.
Name:	ae86 dash removal.jpg
    john
    nsw
    liverpool
    you have to take out the tacho/ cluster thingy ... there will be 4 bolts or so 2 on top and 2 on the bottom ...
    Dim
    Menai
    Yeah Cluster and Cluster surround has to come out mate.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    You need to pull the knobs off the switches and unbolt them in order to pull the cluster out. The service manual has step by step instructions on how to do it.
    Veteran drift kid's Avatar
    Glossodia
    ^^^ +1 take the washer switch out and the lights switch and undo the nuts, that should help. gl
    Glossodia
    i dunno if this helps, but this is a shot of mine with the dash out, you might be able to spot some thing helpful.
    Senior Member Marco's Avatar
    Marcus
    Jindalee
    yeah cluster and switches for lights and wipers. and take good note of how it all goes back together.
  1. AE86 Black dash + Blue dash + Parker lights for sale
    Last Post: 7th July 2012, 12:06 AM
  2. [SA] - KE70 Tacho dash & Uncracked brown dash pad
    By Seventy in forum Car Parts For Sale
    Last Post: 25th November 2011, 04:06 PM
  3. WTB RHD dash assembly package: dash, steering column etc.
    By Corollaman5 in forum Cars or Parts Wanted
    Last Post: 8th January 2009, 09:37 PM
  4. Removing AE86 Dash
    By Jamekins in forum Technical - Questions
    Last Post: 14th August 2008, 02:56 AM
  5. Removing Dash and air-con vents
    By brad in forum Technical - Questions
    Last Post: 14th November 2005, 09:45 PM
