Results 1 to 7 of 7
Thread: TRW Lucas GP600 Racing Brake Fluid
    Senior Member gslrallysport's Avatar
    Greg
    Default TRW Lucas GP600 Racing Brake Fluid
    Lucas Grand Prix 600 Racing Brake Fluid!
    Unlike other RBF600's Lucas is backward compatible with the lower DOT fluids, so if you get stuck needing to fill up with other fluid, it won't have any adverse effects, other than lower its performance...
    TRW GP600 Dot 4 Racing Brake Fluid
    Dry - Min 310
    Wet - Min 204
    That's about the best out there short of Castrol SRF, or GS610. But significantly cheaper than either of them at $65 for a 1L bottle.
    For comparison, some other popular brands:
    Motul Dot 5.1
    270 dry
    185 wet
    Castrol Response Super Dot 4
    286 dry
    184 wet
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    User fantapants's Avatar
    Pat
    sorry i might be really dumb bbut what is the wet and dry number refering too? sorry for the noob question
    06/07/2011
    Greg
    Wet and dry refers to the amount of moisture that the fluid has absorbed. 'Dry' refers to 0% water, whilst 'wet' refers to 2% moisture absorbtion. Pretty much all Dot 4 brake fluid, whether it's high performance (like an RBF) or normal street fluid will go 'wet' after between 6-12 months.
    That's why replacing fluid regularly is more important that buying super duper pads as you can see the massive difference 'wet' makes to fluid performance.
    Also, need to update that, the 1L bottle is now $65... still miles cheaper than SRF at $130/L....
    Greg
    Have a squiz here:
    http://en.wikipedia.org/wiki/DOT_4
    I'm sure out standard for wet is only 2% (not 3.7%), but I could be wrong... either way wet is no more than 12 months of regular use.
    Pat
    oh so its boiling point?
    thanks for the heads up
    06/07/2011
    dan
    adelaide
    adelaide
    silicone based?
    Greg
    Quote Originally Posted by cracker View Post
    silicone based?
    No, so it's fine for street use, and fine to mix with existing brake fluid (ie. don't need to flush system out completely before use).
  1. An insight into Brake Fluid
    By motorculture in forum BENDIX Put your foot down with confidence.
    Last Post: 28th August 2012, 06:55 PM
  2. Fluid in brake booster?
    By ae86 slide in forum Technical - Questions
    Last Post: 12th October 2010, 09:54 PM
  3. leaking brake fluid ?
    By sun_moon in forum Technical - Questions
    Last Post: 5th April 2010, 06:51 PM
  4. Which oil/brake fluid
    By willa in forum Technical - Questions
    Last Post: 30th October 2009, 11:01 AM
  5. brake fluid loss
    By slippry in forum Technical - Questions
    Last Post: 23rd March 2007, 08:51 PM
