Results 1 to 10 of 19
Thread: carby install 4age - using 4ac setup
    john
    nsw
    liverpool
    Default carby install 4age - using 4ac setup
    hi guys ,.
    as the title states. i was wondering if this is possible ... to take out the 4ac and drop in the 4age and use all the 4ac wiring and its disturbor for a signal and all that stuff .. the way i see it is that the im just taking out a old carby motor and dropping in a newer cabry motor. ...
    Jonathan
    Mmmmmm. I have seen this done, or a weber at least. Scary stuff. Not nice.
    Generally, the answer is no.
    john
    nsw
    liverpool
    thanks for the reply jonny, but can you please elborate...
    sorry to confuse anybody but i meant to say is take the 4ac out and install a 4age with side draft carbs... and use the standard 4ac wiring, distributor and fuel system,
    Veteran blair's Avatar
    Blair
    Sheldon
    generally if you have to ask, i doubt you have the ability/skill level to do it?
    will be a giant headfuck.
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    if you want to do it that way you can get the 4age dissy and the 4ac disy and kinda graft the 4ac dissy onto the 4age dissy shaft, that will sort you out ignition wise
    or you can run locked timing and it will be just a little hard to start in the mornings
    u buy a bosch module from i think a falcon?? unsure of car but the part number for this module was BIM 024 this allows you to run the 4age dissy un modified, to wire the module u go by the numbers on each of the 4 terminals coming from it
    i cant remember the numbers as i did this a long time ago now
    looking at the modulefront on the 2 terminals on the left go to the dissy (theres 3 wires on the dissy 1 is unused) and the 3rd one along goes to positive side of the coil (i think) and the last one gets earthed, the module itself is also self earthing so u will need to attach it to a god earthing surface
    thats about all the info i can remember, the diagram for this was lost ages ago
    but what you want to do is very do able and very easy if you can work out the module i mentioned above the rest is all just plug in and away you go.
    also need to block up injector holes when using carbs, we used welsch plugs and just tapped them in,
    also with the standard wiring being used, pull the oil pressure sender from the 4ac and instal on the 4age so the light will read correctly, or use A/M guage
    p.s. blair... jason and i did the module in the ke70 your setup came from.... do u mind taking some close up pics of the module and telling me which numbers on the mudule go where, what i mentioned above is just from memory
    hope i helped
    MY JZX83 (clicky)
    john
    nsw
    liverpool
    Quote Originally Posted by blair View Post
    thanks for the input mate... did you really have to make a comment like that(make you sound like a cock imo) . no need to flame some one who asks, maybe for you a simple question with a simple answer. you might know how to do it .. so why not just share your wisdom instead of flaming me ... thanks dude ..
    for everyone else thanks for the input. and yeah i was looking at my brother's standard virgin engine bay and thought logically ... if a 4ac came out of it and has all the elements to run a carby motor.. i asked my self the question why cant a 4ag carb be put in and maintain the factory setup.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Remember, it won't be legal to register either, unless you can prove that the emissions from the car are no greater with the carbies than what they are from a standard EFI system. That in itself would be a pain of a job, expensive and if not impossible.
    Blair
    Sheldon
    wow i actually just reached for the camera to go take some photos to help you
    ohwel.
    /end keyboard warrior fight.
    i didnt mean to come off like a cockhead before, will take some shots in a sec
    Blair
    Sheldon
    blue off dizzy -> 7
    white off dizzy -> 3
    black and red -> relay then ?
    earth -> earth
    bosch module
    silver and gold to blue and white
    relay setup that other red and black go to
    and case (lol)
    entire setup
    hope this helps bud and goodluck
    john
    nsw
    liverpool
    thanks mate appreciate it ..
  1. Twin carby setup for 4AGE
    By Meeksie in forum Cars or Parts Wanted
    Last Post: 25th August 2010, 10:46 PM
  2. wtb rwd 4age twin carby setup
    By kali_man_tan in forum Cars or Parts Wanted
    Last Post: 15th September 2007, 06:29 PM
  3. 4age carby setup
    By dazstar86 in forum Technical - Questions
    Last Post: 17th September 2006, 06:48 PM
