Results 1 to 4 of 4
Thread: HKS Supercharged AE86
    Junior Member cswan's Avatar
    ACT
    Barton
    Smile HKS Supercharged AE86
    So far:
    Aus-spec AE86 Sprinter
    Bottom End
    7 rib 4AGE
    Forged low compression pistons (Toyota 4AGZE)
    Balanced conrods
    Balanced stainless steel crankshaft (100kw)
    Techno toy tuning overdrive crank pulley
    Head
    Ported and polished big port
    HKS 272 degree intake and exhaust camshafts
    HKS cam gears
    HKS 2mm metal head gasket
    Induction
    HKS AE86 Supercharger kit
    - supercharger has direct drive - ie no clutch like 4AGZE
    T3 overdrive crank pulley (for more boost)
    K & N pod filter
    Fuel injection
    Motec M4 ECU with wideband lambda and data logging
    Sequential injection
    4AGZE (365cc) injectors
    Map sensored boost pressure
    Air intake sensor
    Water temperature sensor
    Cooling
    Oil cooler
    China-spec 52mm alloy radiator
    Twin thermo fans
    Exhaust
    HKS Superheader II
    2 in cat back
    Drivetrain
    Aus-spec T50
    T18 tailshaft
    Early/Zenki disc - disc rear
    TRD 2 way LSD
    4.77 final drive ratio
    Suspension
    Tokico HTS 102 adjustable dampers
    TRD 8kg/mm coilover front springs
    TRD 6kg.mm rear springs
    Adjustable front lower control arms
    T3 tension control rods
    T3 adjustable upper and lower rear arms
    T3 adjustable panhard rod
    T3 traction brackets
    T3 roll centre adjusters
    Whiteline heavy duty adjustable front sway bar
    Whiteline heavy duty adjustable rear sway bar
    Urethane bushes elsewhere
    Brakes
    Standard discs rear
    MA61 discs and calipers front
    Goodrich braided brake lines
    More to come. Will update with pics from time to time.
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    welcome
    post pics of the supercharger, i've never seen one. what advantages it there with th hks on over a sc12/sc14?
    sounds mad, good spec list.
    bursting ovaries since 92'
    ACT
    Barton
    Attachment 15458
    The kit bolts up to a big port head and was designed specifically for the AE86.
    The supercharger was made by Ogura and is about 1200cc capacity, somewhat bigger than the ZE charger. (There's no clutch.
    There was an HKS computer module that adjusted the standard ae86 ecu settings, but I have never run that, just the Motec M4.
    Although the kit was designed to use the standard size NA crank pulley and standard compression pistions, I got the low compressed ZE pistons, used a thicker gasket and the ZE crank pulley. This enables me to run a lot more boost than standard.
    The motor generated plenty of heat with that setup.
    There's no intercooler, so the charged air seems to get pretty hot at high revs. It'll take a bit of working out, but water injection to the intercooler is a possibility.
    It took yonks to find all the parts: I have a spare SC and 2 spare intake manifolds which I needed to by just to get the missing bit between the SC and throttle body...
    It makes boost very low down in the rev range and screams it's bits off. Sounds great with the cams too.
    Dunno what power it makes, but will find out when I get it running again soon.
    Anthony
    Haha nice. I fitted one of these kits to a guys KE70 a while back. Well, fitted what was left of the kit anyway. Had to make a lot of brackets,pulleys and tensioners to get it all working. In the end it did work quite well though. Would love to see some pics if you have the full hks setup if you have that.
  1. HKS Australia - Supercharged Toyota 86
    Last Post: 1st June 2013, 04:39 PM
  2. (VIC) s13 hks coilovers, wheels, hks intercooler
    By kickit in forum Car Parts For Sale
    Last Post: 20th June 2011, 06:40 PM
  3. 4AGE and 4AGZE HKS Valve springs and HKS Cam Gears
    By ap2002 in forum Car Parts For Sale
    Last Post: 26th March 2010, 10:15 AM
  4. supercharged AE86 for sale Sydney *PICS added*
    By sprintah! in forum Cars for Sale (Toyota Only)
    Last Post: 8th October 2007, 05:14 PM
  5. HKS ae86 turbo manifolds
    By mtgg85 in forum General Topics (No Technical Questions)
    Last Post: 21st November 2005, 12:21 PM
